Question about Fuji FinePix Cameras
My fuji finepix s1600 camera won't turn on
The camera will not turn on
Posted by Gwen Fehr on
5 Related Answers
Anonymous
  • 6966 Answers
SOURCE: Memory full
As you posted, both cameras have their memory full then you need to free up the internal memory either by deleting the contents or transferring them (the pictures) to your computer.
To transfer to your PC, you would need the installer/driver CD that came with the cam as well as a USB cable. You need to run/install FinePix Viewer prior to the USB connection. Follow on screen instructions. When asked to connect the cam do so. All others are explained with illustrations on the User's Manual. A copy od the A700 User's Manual is available here.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 14, 2007
Anonymous
  • 65 Answers
SOURCE: Need Fuji FinePix A500 Software
Go to their website, Its a whole lot easier just to get a external card reader or use one thats built in your pc if you have one...
Posted on May 28, 2008
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: Fuji Finepix z1
Download the manuafrom Fuji WEB sire.
You need to format the memory card, you need to goto the menu and scroll through the various settings to the memory card format function.
Posted on Jan 17, 2009
robmcd27
Rob
  • 423 Answers
SOURCE: memory card not working? ( fuji finepix Z20fd Digital Camera)
Hi there.
When you start using a memory card, you must format the card in the camera first...using the camera menu. If you don't the camera won't read the card properly. Try that and I bet it will work for you.
Rob
Posted on Mar 09, 2009
SAFFOTO
Jeff
  • 78 Answers
SOURCE: Finepix J20 Digital Camera- says:PROTECTED CARD!
My bet is that the little switch on the SD card is in the "lock" position. Switch it off and try again...
Posted on Jan 29, 2010
Testimonial: "Hi I left the comment about the Fine Pix Fuji J20 camera, and I am not sure where the sd switch is on the camera. please if you can let me know.Thanks"
Fujifil finepix s1600 manual
Follow this link: http://translate.google.no/translate?hl=no&sl=en&tl=no&u=http%3A%2F%2Fwww.camerauserguide.net%2Ffujifilm-finepix-s1600-s1770-camera-users-manual-guide-owners-instruction%2F6273&anno=2
Apr 07, 2014 | FUJIFILM FinePix S1600 Digital Camera
I need manual for Finepix 1600
Fuji has the manual for the Finepix S1600 on their product page. It's a discontinued model. The direct link to the manual is http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/s/finepix_s1600_manual_01.pdf . You will need Adobe Reader or a similar product to read or print the manual.
I hope this helps.
Apr 07, 2013 | FUJIFILM FinePix S3200 / S3250 Digital...
My fuji finepix s5000 has lost power
see this causes and proceed . God bless you
If the camera won't turn on, check the batteries, or connect the camera to an AC adapter. If that doesn't work, remove all batteries, disconnect the AC adapter, wait a minute, reinsert batteries and reconnect the adapter.
If the flash doesn't work, the camera won't take pictures, or the screen keeps turning off, check that the batteries are strong.
Oct 16, 2012 | Fuji FinePix S5000 Digital Camera
My new windows 7 wont except my s1600 fuji finepix camera...i installed the software that come with the camera, i have also unistalled the cam and reinstalled twice just to make sure.....also i get a...
dobrý deň.,chcel by som sa spýtať že aký program si mám nainštalovať k notbooku Samsung R730 a mám foťak FUJIFILM FINEPIX S1600 aby som vedel pozrieť a nahrať si nafotené obrázky z foťaku do notbooku.,ďakujem.,a kde najdem program.,ak taký existuje.,lebo na Cd-čku to nejde.,lebo som skúšal už viackrát.,ďakujem vopred Odpoved mi možete zaslať na [email protected]
Aug 18, 2010 | FUJIFILM FinePix S1600 Digital Camera
Camera freezes when using aperture and speed
Try updating the firmware. The update does not specificly mention this problem, but maybe it will help anyway.
You can download it from here:
http://www.fujifilm.com/support/digital_cameras/software/#firmware
Make sure your batteries are fresh before updating.
Jul 28, 2010 | FUJIFILM FinePix S1600 Digital Camera
My CD with my Fuji s1600 digital camera does not give an english language version of the manual despite being marked UK
From memory, I hunted on the CD that came with the Fuji S1600 and it wasn't the version that had uk in the name but the one that had en. Hope that helps.
Jan 28, 2010 | Fuji FinePix S700 Digital Camera
Cameras Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Rob Hill
Rob Hill
Are you a Fuji Camera Expert? Answer questions, earn points and help others
