Question about Canon PIXMA MP830 All-In-One InkJet Printer
Cannon printer error code 6A00
Posted by champso7 on
  • 6 more comments
  • Anonymous Feb 13, 2008
    6A00
    ERROR 6A00
  • Anonymous Feb 23, 2008
    I have an error code 6A00...ink tank does not light up or move..the alarm lights is on...I can not perform an functions other than turning it off and on...Please help
  • Anonymous Mar 05, 2008
    Brand new today 5/3/08 - Loaded ink tanks.
    hought I was ready to calibrate and get started. 6A00 error code appeared.
    tried switching off, unplugging and waiting. No effect.
    printer tried switching itself on sevral times.
    I will contact the seller tomorrow for advice/replacement.
    Canon's technical advice on website would not load and their warranty insists on accepting unacceptable conditions for data transfer outwith EU.
    I'm not a happy chappie.
  • ekosborne Aug 13, 2008
    There was a plastic gear grinding sound, down by the print cartridge area, after the machine was turned on and trying to engage. This happened several times so it was turned off. In checking the ink cartridges (they slid smoothly) the "Print Head Lock Lever" was released and engaged and the machine was turned back on. The cartrigdes sound like they are sliding, but the 6A00 Error Code comes up.
  • bbaum Aug 20, 2008
    A Canon MP 600. Sounds like a (plastic) gear grinding.  Occurred after paper jammed twice.  Have used printer less than 2 weeks (though it was a add-on feature with purchase of a MacBook Pro 5/23/07; I had kept using an Epson Stylus 4600 which had performed beautifully for 4 years!).
    From what I read on blog, sounds like I'm stuck with junking this Canon.
  • Anonymous Oct 08, 2008
    First I started getting 5C10 Error messages and while trying to fix that (restarting did not help, so I tried to reset it) it turned to 6A00 Error message. I have a 3 year extended plan warranty, but haven't called Canon yet. I guess I will have to do that and hopefully they will take care of it.
  • alami12 Dec 13, 2008
    Hi, I got eurror cood 6AOO CAN YOU HELP PLEASE
Anonymous
There are some more things to try discussed at:
http://www.fixyourownprinter.com/forums/inkjet/39177
Hopefully you will fix it
Posted on Apr 15, 2008
jimyard
I have had two error codes with my Pixma 830 both occuring after 1 year ownership. Canon repaired the first under warranty, the second is on me. The cost of having it looked at is $75.00 a new HP is $125, and they don't require proprietary ink cartridges. This machine is way too sensitive, and cannot be services unless you have a Canon franchise. I'm going to throw it away.
Posted on Mar 06, 2008
Anonymous
I had the same problem and contacted Canon about getting a replacement and they never got back to me. Then one day the error message was gone and it started working again.
Posted on Feb 14, 2008
Anonymous
MP830. Carrage is stuck on right
Posted on Dec 28, 2008
  • Anonymous Dec 28, 2008
    How to unlock carage. It is stuck to Rt
arben pllana
  • 1,006 Answers
6A00 is a problem with the sheet feed unit.
Follow Canon's suggestion, take it or send the unit UPS to the Authorized Repair Facility.
You will NOT be able to resolve the problem yourself.
Posted on Nov 01, 2007
6A00 error code
6A00 is a problem with the sheet feed unit. I would get in touch with Canon, to hopefully get it repaired. Not much you can do yourself sadly.
Nov 22, 2012 | Canon PIXMA MP830 All-In-One InkJet...
Error code 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All The Best: Pineworks
Apr 02, 2010 | Canon PIXMA MP830 All-In-One InkJet...
ERROR CODE 6A00
Effective Solutions to Troubleshoot Canon Printer Error Code 6A00: Cartridge faults are not always easy to deal with.
Solution 1: Check Print Head Carriage
  • Make sure whether the printhead carriage is moving back and forth properly or not.
Solution 2: Check the Purge Unit
  • If you have just moved the printhead assembly, the purge unit error will still be there.
Solution 3: Reseat the Ink Pads
  • Press down the ink pads down in the purge unit.
To know more: Canon Printer Error Code 6A00
Jan 23, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Canon Mp780 error code 6A00
6A00 is not a jam error, it is an error of the purge assembly not cycling properly. Many times a paper scrap jammed in the capping assembly or the squeegee assembly caught on the filter assembly. Usually worn out gears and dried ink so that replacement of the purge assembly is the best fix.
Jan 19, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Service error 5c10, error code 6a00 wored
6A00 is the error when the purge assembly is broken or jammed. You need a shop to install a new one since the entire print engine has to come out to replace it.
Dec 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
MX850 ERROR CODE 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Oct 05, 2009 | Canon PIXMA MX850 multifunction InkJet...
Canon pixma mp800 error code 6A00
6A00 means you need a new purge assembly. That's the unit that cleans the printhead. Part number is QM2-3032-000 around $30.00 but a shop should install it.
Jul 24, 2009 | Canon PIXMA MP830 All-In-One InkJet...
6A00 error
The error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
apparently the best way to deal with this is to turn it upside down and give it a shake.
hope this helps
Sep 23, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Error code 6A00
Error Code 6A00 is a problem with the sheet feed unit. You cannot fix it by yourself because you do not have the tools to fix the printer.
You go to a Canons Support Page and ask for a replacement if it is still under warranty or you replace the printer with a new one.
Aug 16, 2008 | Canon MP830 All-In-One Printer
MP600
when i turn on my mp600 canon printer i get the same error code 6A00! i cannot do anything with the printer, please help!
Apr 08, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
852 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
