Question about Lexmark X4270 All-In-One InkJet Printer
X4270 ALL IN ONE WILL NOT PRINT ERROR 1203 COMES UP,
ERROR 1203 COMES UP, TELLING ME THAT MY PRINT CARTRIDGE HAS A SHORT, I DID WHAT THE BOOK SAID TO DO, BUT THE SAME CODE 1203 CAME BACK UP . COULD THE INK CARTRIDGE BE NO GOOD ? I REFILLED IT AT ONE TIME. (CAN SOME ONE PLEASE TELL WHAT I NEED TO DO).
Posted by RASSTER on
arben pllana
  • 1,006 Answers
Noticed you message while searching for answers to repairing another Lexmark printer. You probably already have the answers by now but here is what the manual says.
Hardware Error: 1200
The All-In-One is stalled.
1. Press Power to turn off your all-in one.
2. Unplug your all-in-one fro the wall outlet.
3 Check for paper jams.
4 Plug in your all-in-one
Cartridge Error: 1200
The cartridge carrier is jammed.
1. Turn off you all-in-one
2. Unplug the all-in-one form the wall outlet.
3. Open the control panel.
4 Open the cartridge access door
5. Make sure the cartridges are snapped in place in the carrier.
6. Check for objects obstructing the carrier.
7. Plug in your all-on-one
8. Press power to turn your all-in-one back on.
Hope this resolves your issues.
The ultimate fix for this problem is to give your Lemark and Dell printers to people that you really dislike. Let them live with the frustration. Then buy yourself a Hewlett Packard, Canon, or Epson printer. Check the cost of the cartridges for each brand prior to making a purchase. Purchase the printer with the least expensive cartridges and one that will take the generic (compatible) cartridges available in retail stores and refill stores. My personal favorite are the Epsons. They print excellent colors and are very affordable to own, and most important, operate.
Let me know if it works?
Posted on Nov 01, 2007
Hi, i'm getting error message 1203 on the printer and we've lost the user's manual. Can you tell me what this is?
Error 1203 is a very interesting error code. Here is what I found out about error 1203
Error 1203 is a very interesting cartridge error. It means your cartridges overflow even from brand new cartridges after a several prints or right after you refilled the cartridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge
Solution:
I use the lint free cloth(coffee filter work great) with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
Then before you print anything, you should run aligned the cartridges a couple times then run clean cartridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of lint free cloth(coffee filter work great on those holder contact panel.
Article on refilling Dell ink cartridges
Rick
Sep 10, 2011 | Dell 926 All-In-One InkJet Printer
What is error 1203?
Error code 1203 on this printer model is a Shorted print head circuit, this can be the cartridge (most common) or it can be the print head floating ribbon is shorted.
Jan 16, 2011 | Dell 926 All-In-One InkJet Printer
I have a lexmark all in one 7100 series with an error code of 1203. What is this?
Hello.
In Lexmark 7100 series, an error code 1203 indicates that your print cartridge has a short.
Follow these steps:
  1. Press Power to turn your All-In-One off.
  2. Unplug your All-In-One from the wall outlet.
  3. Plug in your All-In-One.
  4. Reinstall the cartridges.
If this does not work, then your only option is to replace your cartridges.
Nov 23, 2010 | Lexmark Office Equipment & Supplies
IT KEEPS TELLING ME THE RIGHT CARTRIGE IS WRONG, ERROR #1203, WE LOST OR OWNERS GUIDE
Here is what Lexmark says:
Cartridge Error: 1203 Your print cartridge has a short.
If this does not resolve the problem, see More troubleshooting options, or replace your cartridges.
Also the cartridge that should be installed looks like Lexmark 32 ink for black and 33 ink for color.
Mar 25, 2010 | Lexmark X5470 All-In-One InkJet Printer
Dell 926.... the printer will not acknowledge that a new cartridge has been put in. It will not work. previously had the error code 1203, a short circuit in print head. That has now disappeared. Help...
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Aug 10, 2009 | Dell 926 All-In-One InkJet Printer
Dell Printer 926 Error 1203 "Print Head Short"
Error code 1203 means that you have a print head short error. The way to fix this is to:
1) Clean the contacts on the cartridge w/ a damp cloth. Only do it in one direction so that you're not smearing ink all over the contacts!
2) Disconnect and then reconnect the power cord from the wall and from the back of the printer. Wait about 30 seconds, and then plug everything back in.
If this doesn't work, you may need to replace the ink cartridges...you can always try it one more time just to be sure
Jan 09, 2009 | Dell 924 All-in-One InkJet Printer
Error 1203 What do I do?
Aug 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error Message 1203??
These steps are for a Lexmark 4200, but I suspect they will work for your printer as well:
Source: http://www.lexmark.com/publications/pdfs/4200/eng/trouble.html
Aug 04, 2008 | Lexmark P4350 All-In-One InkJet Printer
Error message 1203
This link should have the answer for you.
http://www.dellcommunity.com/supportforums/board/message?board.id=A940&message.id=13761
Jul 27, 2008 | Dell 924 All-in-One InkJet Printer
Error 1203
You can try testing your Printer with another Print Cartridge and if the error message repeats, you should contact Service Center as then there would be a Hardware Problem.
Jul 15, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark X4270 All-In-One InkJet Printer Logo
112 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
