Was there a power failure? unplug unit for a min and plug it back in. hold power button til unit turns on. If it still flashes you may have a power supply problem inside the unit.
Your model the VS-60111 is the V20A chassis which doesnt have a DM board. I can assist with the issue but will need to know what the set does when you pug it into the electrical outlet and also what happens when you press power? Any lights? if so what color and is it solid light or blinking? Please respond to this same post for further assistance.
You cannot be sure of the problem unless you try the error code operational check. Here are the instructions for doing it Turn off the tv from the remote and unplug it. Plug it back in . Press and hold the menu and Device/Input buttons on the front panel of the tv for 5 seconds. The LED will blink a certain number of times, pause for half a second followed by another series of blinks. Count the number of blinks before and after the pause so that I can tell you what the problem is.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
i have a mitsubishi vs-60111 when i watch the tv as of last week the color is pale like green color or green,gray color the picture is sharp yet , i took front cover off the lights are still bright red , green and blue what can be the problem / joe
Turned out to be a problem with my dish receiver. Found out by attaching a separate DVD unit to the TV, and it didn't flash. I then realized everything ran through the dish receiver. Called them, reset ( by unplugging for 90 seconds) and all was well.
I would check for Bad solder joints around the flyback, and the verticle and horizontal yoke plugs for starters. Lower your volume and listen if you hear the high voltage come back up when your video comes back up. Let me know what you discover when you check the solder joints.
