The Interlock Monitor Switch is an added
safety check on the Primary and
Secondary Interlock Switches. If the
Primary and Secondary Interlock Switches
allow the oven to operate with the door
open, the Monitor Switch will blow the
fuse.
You can get more information about adjuting the interlock switch from this link
http://136.166.4.200/contents/Microwave/LMVM1935xx/LMVM1935xx_Service_Manual.pdf
sections 7-11 thru 7-12 discuss the door interlock adjustment that will cause the 20A fuse to blow if it isn't set up right. I hope this helps you...
