Question about HP Compaq ProLiant ML750 Server
Network Connection Takes a very long time and gives this message ((preparing network Connection)) does not work
Posted by alaa din on
  • 1 more comment
  • alaa din
    alaa din Apr 07, 2014
    I can not log on to the computer so that I can change my network settings I changed with the network card did not solve the problem please help
  • jarrett622
    jarrett622 Apr 08, 2014
    Why can't you log in to the computer? You need access to change any of the networking configurations or add connections.
  • alaa din
    alaa din Apr 08, 2014
    Can not log in to the computer because he stands at the ((preparing network Connection)) for a long time without access to the system and I have a Windows 2000 Server and I cut off all network cables him please help
jarrett622
    Scholar:
  • 74 Answers
Settings are not correct, network misconfigured, or your ethernet card is bad. If this is a wireless connection you may need to add a connection manually. You will have to know all the security settings to use. If this doesn't resolve it your wireless card or dongle may be bad.
Posted on Apr 07, 2014
I found a Trojan on my Acer aspire 5250 running win 10, I'm stuck on blue screen with critical system failure. Have rebooted dozens of times, have tried alt f10, and I'm stuck in a godforsaken loop. Any...
Try the Kaspersky Rescue Disk. You will need a USB flash memory device ("memory stick") and a working computer with Internet access to download and prepare the Rescue Disk program. Follow the directions in the page linked below. The USB memory should be at least 512 MB, formatted as a FAT32 device, and contain no critical files (contents will be wiped by the preparation process).
How to record Kaspersky Rescue Disk 10 to USB device and boota computer...
The Rescue Disk takes over the boot process and runs its own operating system rather than the one that has been sabotaged. Consequently, it is not blocked by damaged or bypassed system files on your hard drive, and can get into them for repairs.
If you wish to retain the Rescue Disk for future use, follow the links for updating its virus removal database to see what information you will need to make a network connection (numbers from the Network Control Panel of your computer once you get it running again). Since the Rescue Disk operating system is necessarily minimal, Internet connection information has to be entered manually. You may find it simpler to make a fresh Rescue Disk install instead if you are confident you will have access to a working computer the next time you need to do so.
Jul 25, 2017 | Acer Computers & Internet
My phone won't send messages I got credit and still won't. also Mob internet don't work
You Can Unlock Your HTC Desire . Call Your Network Provider To Ask Your HTC Phone Unlock Code. But your Network Provider Takes Time To Give You Unlock Code.
If You Want Your Imei Unlock Code Instantly. Buy HTC Imei Unlock Code From Third Party. Many Site Available Online To Provide Imei Unlock Code.
I Hope This Will Help You.
Thank's
Oct 05, 2011 | HTC Desire Cell Phone
Dear Sir; please give me soluion this problem. Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server...
Dear Sir; please give me soluion this problem. Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Error: Server returned unrecognized reply
Sep 01, 2011 | Lantronix CoBox-FL-IAP (COBOXFLIAP11)...
Have a problem getting online, computer says " no network controller - no ethernet controller/ or driver's"... Also: appears to be something missing in the smaller panel underneath computer!!! ...
Your computer is missing the drivers for the local area connection or the wireless network connection that is why its giving that message. Who is the make of your computer? when was the last time the computer was working fine. Which operating system are you using?
Feb 14, 2011 | Computers & Internet
Playstation network timed out
Usually this is due to a problem with the Internet connection. Check a few things. 1. what is the signal strength. Anything under 30% could give you this message. 2) is your internet connection down? 3) Is the date right. The last one is a big one. Certificates like you would get on a secured website (https) check the date to see if the cert is expired. This could give you problems. 4) if all else fails, reboot the router and see if it helps.
May 04, 2010 | Sony Playstation 3 (PS3) Console
Everytime i send a msg on my ks360 it says: sending failed, why is this? i have credit and my sattelite connection has maximum bars
The error could be because of a wrong message center Number.
  1. Go to your message settings (should be message>message settings)
  2. Check your message center number
  3. compare it with that of someone else sending messages successfully on your network.
  4. If yours is different, change to the correct one (make sure you write down your center number somewhere safe just in case).
If this doesn't work, then it could just be a network failure on the part of your carrier. Just give it a little time and try again
Oct 05, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
N80 takes a long time/slow in sending sms
CHECK THE NETWORK FIRST.. IF THE NETWORK IS WORKING FINE.. TRY RE PROGRAM YOUR MOBILE GO TO ANY MOBILE IN YOUR ARE THEN RE MAKE IT REPROGRAM..
Aug 29, 2009 | Nokia N80 Cellular Phone
Crossover cable connection
dear you have to prepare new cross cable
of cat 6 as following sequence
for one side it is
orangewhite,orange.
greenwhite,blue,
bluewhite, green,
brownwhite,brown
and for second side it is
greenwhite, green,
orangewhite,blue.
bluewhite,orange
brownwhite,brown
try and reply
Apr 12, 2009 | Computers & Internet
HP Compaq ProLiant ML750 Server Logo
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
