Question about Kyocera FS-4000DN Laser Printer
Error f000 kyocera fs-1120 - Kyocera FS-4000DN Laser Printer
5 Related Answers
Anonymous
  • 56 Answers
SOURCE: Kyocera FS-2000D
Hi, Sound like drum unit is out off position.
Switch off printer.Open left side door, remove waste toner bottle and push drum unit(with grej lever on it) in printer to proper position.If grey lever is not in proper position, drum will be not locked.Place waste toner bottle in position.Switch on printer.
Posted on Nov 06, 2007
Anonymous
install new firmware
Posted on Dec 18, 2007
Anonymous
SOURCE: Call Service F000 error
F000 is a panel communication error... update firmware... firmware as far as i know isnt available to the public... contact kyocera
Posted on Jan 15, 2009
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Posted on Jan 23, 2009
Anonymous
SOURCE: CLEANING A KYOCERA FS-2000D
Follow the page http://www.fixya.com/support/t1336338-kyocera_fs2000_thin_black_vertical_line
Basically, you remove the cartridge and developer all at once, then remove the waste toner bottle, then push the grey tab in to release the drum cartridge (be very, very careful in removing and putting back in. Any scratches on the drum and you will enjoy black spots permanently on printouts).
On the right side of the grey charger section is a tab you can use to release it. Do this, then put the drum away in a light tight back to prevent damage to it.
The reason why this Kyocera printer doesn't have the primary charger wire cleaner is because it did away with it. It now charges via a black fuzzy looking roller on top which is like the secondary corona charger wire, which then applies it to a roller, which then applies it to the drum. I think this is nice since it should prevent printer quality problems better since there is nowhere for oxidation to really collect. But, OTOH, it does happen anyhow.
I cleaned mine off and the streaks disappeared. I used a non amonia based cleaner to help, since I didn't find any dust on it to begin with. Whatever you choose, do not get your fingers on it, or it will put oil onto the rollers and that will make it worse.
Worked for me.
Posted on May 25, 2009
WHAT DOES ERROR CODE F000 MEAN IN: ECOSYS FS-6525MFP KYOCERA COPIER MACHINE?
Possible power board defective or connectors need to be un plugged and plugged back in good luck
Nov 07, 2017 | Kyocera Office Equipment & Supplies
MY ECOSYS FS-6225MFP KYOCERA COPIER, DISPLAYS AN ERROR MESSAGE F000
Unfortunately you will have to replace the Main PCB. If it still under warranty you could send it back to your supplier.
I HAVE AN ECOSYS FS- 6525MFP KYOCERA COPIER PRINTER. IT DISPLAYS ERROR CODE F000 WHAT CAN I DO TO RESOLVE THE PROBLEM?
Code
F000
Description
Main PWB - operation panel PWB communication error
Causes
Defective main PWB.
Defective operation panel PWB
PWB = printed write board
https://printcopy.info/?l=en&mod=erc&brand=Kyocera&model=FS6525MFP&code=F000
Machine failure call service f000
Idea: You can look up the failure codes online in the Kyocera website. Just download the maintenence manual.
Feb 10, 2011 | Kyocera FS-C5030N Led Printer
Facing Problem in Canon Colour laser copier 1120
your a, b and c side sensors are bad they are found next to each other in the transfer drum
Sep 12, 2008 | Canon CLC 1120 Color Copier
F000 error message on Kyocera FS-3830
just update firmware thats the only solution
Apr 29, 2008 | Kyocera Office Equipment & Supplies
Kyocera FS-4000DN Laser Printer Logo
96 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
