Problem: World can't see Tomcat served web pages through ATT UVerse 2wire modem/router/firewall. Everything used to work. The webserver PC died so I bought a new machine, gave it the same name as the old machine and loaded Tomcat onto it. I can easily view web pages from behind the firewall. I've configured the firewall as best I can to direct inquiries to the new server using the old server's parameters while "cleaning" the firewall of those same directives for the old machine. Using yougetsignal.com's port tester I can see our webcam's port but not the Tomcat port. Calls to ATT haven't helped and they want to start charging me for support.
SOURCE: how connect the edimax BR-6104K router using the PPPoE connection
Let's see if this things work..
First open the internet explorer browser. On the Address bar, type 192.168.2.1.
The site will ask you for username and password. The default username is admin and password is 1234.
The edimax page will appear, click the quick setup wizard.
just follow the instructions. The site will ask of your broadband type; click the PPPoE x DSL and fill up the required information.
Type your Username, Password, and Service Name and other info.
That's It!
Hope this one helps you...
SOURCE: Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
SOURCE: CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
SOURCE: How do I connect to XBox live w/ ATT 2Wire?
to connect your xbox live wireless to 2wire gateway router you need to go to your xbox menu and click on settings then click A on joystick.Go to network settings then select ip address configure automatic ip. DNS should also be automatic. Under advance tab you'll see wireless you need to click connect.if you are prompt to wype encryption its the 10 digit number enclosed in a bracket on the buttom of 2wire router go to
