Question about Proton MM2701VT 27" TV
Upside down tv screen
Upside down screen...tv hasnt been moved, when i connected my laptop with it, my laptop screen is rigt but my tv screen is upside down. even the channels and tv menu are upside down
Posted by Cindy on
    Top Expert:
  • Proton Master
  • 76,416 Answers
Do the picture to broadcasts appear correctly? Provide more details please.
Gopakumar Gopalan Google
Posted on Apr 07, 2014
LVDS issue with RCA 46 inch LCD TV
If you wish to get some details; check the site linked here. Pull up older posts.
Reasons for upside down picture are given.
Jul 13, 2016 | RCA Televison & Video
My tv screen is upside down and cant fix it
I have seen this when on tv you do not use just the exact part for replacement. On computer, you might want to google this since I am sure you are not the only person to have experienced this.
Enter this in google and you will get your answer
upside down screen on laptop
Sep 19, 2017 | Computers & Internet
My ZX 4951 screen is upside down and the Ctrl, ALT and Up arrow combination does not work. Any ideas as I cannot even login.
letl me get this straight
the image on the laptop screen is upside down?
turn off computer
press F8 for Safe Mode
hold down and turn computer back on
see how that goes
May 28, 2012 | Computers & Internet
Sharp tv screen upside down
If you have tried to unplug the set and that does not help contact Sharp concerning this at customer service
Mar 12, 2012 | Sharp LC60LE810UN 60 in. LCD TV
Yamaha mm8 keyboard lcd display only showing half screen
I know this is a lame fix....having similar issue with the mm6;
gently, turn the keyboard upside down, rest on a blanket or something--use your bed?
Leave it upside down for an hour or so, then turn it over and see if it works better. Worked for me.
John 3:16
Nov 30, 2010 | Computers & Internet
TV picture upside down.
go to " SETTINGS " and rotate picture in there , hope it helps , AJ
Nov 03, 2009 | Audiovox VE1020 10.2 in. TV/DVD Combo
Toshiba tp5581a 55 in. rear projection tv.....problem
the yokes need adjusting (upside down writting) and the CRTs need alignment
Sep 11, 2008 | Toshiba 50H81 50" Rear Projection...
Flipped\upside down screen on my compaq
http://forums.techguy.org/tech-tips-tricks/336002-windows-xp-flipping-screen-upside.html
Windows XP: Flipping the screen upside down and back again
Once, at University, someone had flipped the screens of all the public computers (running on Windows XP) of the English Department upside down. The wallpaper, desktop icons, fonts, mouse-cursor and even the start-up screen...everything was displayed or moved upside down. People could not check out their e-mails or surf or do anything.
To reverse the upside down screen mode, press ctrl, alt and the up arrow (arrows console) at the same time; the screen will probably go blank. Turn off the monitor, turn it on again and the display will be normal again. If you possess a sense of humour or are antisocial, press ctrl, alt and the down arrow simultaneously, turn off the monitor, turn it on again and everyone (excluding the culprit) will be desperate --> upside down! Works for Windows XP Home and Prof.
Mar 31, 2008 | Computers & Internet
Image upside down on my Audiovox VE1020
Check the screen position switch, they sometimes get fouled especially if installed in a kitchen.
Apr 07, 2007 | Audiovox VE1020 10.2 in. TV/DVD Combo
TV turned upside down
Well its not a good Idea to carry a TV set turned upside down because of the heavy parts mounted on the board could cause stress and crack the printed circuit board. This what most likly happened. The PC board is cracked. If you have no soldering skills and do not know how to work on printed circuits or solid state devices, you should seek the help of a pro to assist you in this repair. Good Luck.
Jan 01, 2007 | Philips Magnavox MS2530C 25" TV
Proton MM2701VT 27" TV Logo
408 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
ray gallant
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
