SOURCE: phil and teds buggy bumper bar
practical pushchairs is an online store where you can get practically any spares for the phil and teds pushchairs, reasonable prices and only 3.99 to post it to you, good luck,
SOURCE: Wheel bolt missing for rear wheel of phil and ted sport
Contact the distributor and they will mail you the piece you are missing or the entire rear wheel with the bolt connected. If it is out of warranty, they may charge you some, but it should be a minimal amount. www.regallager.com Have your model number information ready for them so they can make sure you get the correct piece for your model. 800-593-5522 The model number and date of manufacturer should be near the rear wheels on a sticker on the frame.
Good Luck! from Moms Just Know
SOURCE: Phill and Ted pram hood hard to put back in place
I have the same problem with a Phil and Ted's Sport - but I believe I have the solution as below. This is taken straight from the Instruction Manual which you can view at: http://www.arango-design.com/Phil-Teds-Sport-Buggy-p/7890-0001.htm - towards bottom of page is a link to the instruction manual - which I was unable to get on the Phil and Teds website. Got this today but haven't tried it yet. Hope this helps.
Really becomes clear when you see the pictures in the instruction manual.
Regards, John
Hood
The sport hood is packed disconnected.
To reconnect:
1. Locate sun hood and hold it facing down, as shown ‘a’.
2. Insert crimped wire ends into frame, through eyelets, ‘b’.
3. Lay hood back (to top of buggy).
4. Locate red coloured pocket at top of fabric seat and insert rear hood wires into each side, ‘c’ and ‘d’.
5.Open hood and attach domes, at bottom of hood, to main seat, ‘e’.
6. Pull eyelet at top of hood over pegs on each side of frame, ‘f’
Note that the windows in the hood are lined with a sun mesh of
a lower shade factor than buggy fabric. Always use sun cream
and clothing for protection of children in direct sunlight.
SOURCE: replacement covers for black and grey phil and teds
Hello there, I can get these for you (if you haven't got them already). The full set is £108.00, and the bumper bar cover is £7. P&P is £4.95
If you're interested please email me on [email protected]
Thanks very much.
SOURCE: how do i take the main seat cover off my phil and ted sport
you have to undo the 2screws each side to remove handle, and there are 2 screws on each side near footrest to undo. then it should slide upp the frame and off where the handle bar connects. sounds more complicated than it is should take about 10-15min. then the whole seat can go in the wash.
