I put a new battery on my isuzu rodeo but I put it on wrong so I made the positive touch the negative and the negative touch the positive and it blew a fuse some where and the car will start up but the battery wont stay charged we have checkied the alternater but its not that what do you think it is
Question edited for clarity to what I think you thought you meant to say :>)
Whomever 'he' is, the one that hooked up the battery the wrong way, will have done all sorts of damage to the electronic modules and in particular the Engine Control Module (none start) and the Body Control Module (wipers). Your car ideally needs 13.2 volts to start. You need an auto electrician with a $5,000 scan tool computer to diagnose the electrical damage and fix. Get the fuel gauge fixed at the same time.
positive cable is red and negative is black or on top of the battery there are markings.One straight line across signifies negative and a cross like this + means positive.I hope i helped.Happy new year.
The first thing to do is to remove the negative cable before the positive cable to prevent any shock and sparks. Battery cables have a nut and bolt keeping the lead made connector snug to the terminal of the battery. After loosening the nut you will need a pair of channel lock pliers to wiggle the battery cables end attached to the battery This will spread the connector open some to remove
1996 Isuzu Rodeo Car Audio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Red/White Car Radio Accessory Switched 12v+ Wire: Brown/White Car Radio Ground Wire: Black Car Radio Illumination Wire: Red/Green Car Stereo Dimmer Wire: Red/Yellow Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 5 1/4′ Car Audio Front Speakers Location: Doors Left Front Speaker Positive Wire (+): Blue Left Front Speaker Negative Wire (-): Yellow Right Front Speaker Positive Wire (+): Green Right Front Speaker Negative Wire (-): Gray Car Audio Rear Speakers Size: 4′ x 6′ Car Audio Rear Speakers Location: Behind the Seat Left Rear Speaker Positive Wire (+): Orange Left Rear Speaker Negative Wire (-): White Right Rear Speaker Positive Wire (+): Orange/Blue Right Rear Speaker Negative Wire (-): Orange/White
Underhood fuse block swap out relay #7 thats the ECM relay. Ground Circuits Using a DVOM, touch negative voltmeter lead to a good ground. Touch positive voltmeter lead to each ground terminal. With vehicle running, voltmeter should indicate less than one volt. If reading is greater than one volt, check for open, corrosion and loose connection on ground lead. See ECM GROUND LOCATION table for ECM ground location. Page 1 of 1 SYSTEM/COMPONENT TESTS - 2.6L EFI -1994 Isuzu Rodeo
here are the wire colors and what each does. 1994 Isuzu Rodeo Car Audio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Red/White Car Radio Accessory Switched 12v+ Wire: Brown/White Car Radio Ground Wire: Black Car Radio Illumination Wire: Red/Green Car Stereo Dimmer Wire: Red/Yellow Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 4′ Car Audio Front Speakers Location: Dash Left Front Speaker Positive Wire (+): Blue/Yellow Left Front Speaker Negative Wire (-): Yellow Right Front Speaker Positive Wire (+): Green/White Right Front Speaker Negative Wire (-): Gray/White Car Audio Rear Speakers Size: 4′ Car Audio Rear Speakers Location: Side Panels Left Rear Speaker Positive Wire (+): White Left Rear Speaker Negative Wire (-): Red/White Right Rear Speaker Positive Wire (+): Orange Right Rear Speaker Negative Wire (-): Black/Orange
There will be a fuse under your hood and one inside the car. The one inside the car can be either under the dash (drivers or passengers), side of the dash where the door meets the dash (drivers or passengers), kick panel by door (drivers or passengers), main console (drivers or passengers)
