Canon IXUS 80 IS Digital Camera Logo
Question about Canon IXUS 80 IS Digital Camera
Digital macro always on
On power up display shows digital macro selected and no control of flash
Posted by r beavis on
My kamera always on macro mode
There may be a setting with
MOUNTAINS
HEAD SHOT, and
FLOWER (macro)
...select any other mode other than the FLOWER
Nov 23, 2013 • Cameras
1helpful
"macro is invalid" is displayed
This error message indicates that the current scene selection mode is not compatible for Macro shooting.
Please check the below figure to view the applicable scene selection modes for the Macro shooting mode.
The macro is not applicable in Landscape, Twilight and Fireworks mode.
You can use other scene selection modes with macro mode.
Thanks for understanding.
I hope the information helpful, if you want any clarification, please let me know.
I have figured out why I can't get the flash on and what macro mode means but how do i turn default the flash on when i power up the camera? The flash is always off when it is turned on and this is a...
The macro mode is for taking close-up pictures. In this mode the flash will not work. There's a slide switch on the end of the camera, near the USB jack. Slide the switch away from the flower and toward the mountain.
Feb 27, 2011 • Cameras
I can not change settings, for example, no flash to flash. When I go to take picture "Digital Macro" appears momentarrilly on display.
You're in the macro mode. Macro mode is for close-up shooting, and the flash is disabled in this mode.
Set the camera to the shooting mode (set the mode switch to the camera position). Press the FUNC/SET button. Use left/right to select a different mode and press FUNC/SET.
How do you turn the flash on
Using the Flash
The flash is designed to function automatically when lighting conditions permit the use of flash.
The camera has 3 flash modes: Off, Auto , and Always On. You can take an image using
a desired flash mode to suit your circumstances. The flash's effective range is
35.4” ~ 59.1”(0.9m~1.5m) (in Normal mode).
The flash is disabled if the camera is set to Macro mode.
1. Press the Power button to turn the camera on.
2. Toggle until your desired flash mode appears on the LCD display.
3. Compose your scene and press the SHUTTER button
to capture your image.
Flash button is the one like an arrow pointing downwards. (not a straight arrow) Usually located beside Disp, OK, Menu.
4helpful
How do I get the flash to work. I have hit what looks like the flash button directly above the Ok button with no success yet in getting a flash to occur when taking a picture. Thanks for your help.
Check to see if your camera is on the macro function. The button is on the left side of the camera (as you are looking at the screen) and it is a slide button. If the camera is on macro, there will be a flower displayed on the screen. This is for close-up photos and will not allow the flash to be set. Slide the button up and a mountain should show on the tool bar of the screen, this is the far away setting. You should be able to set the flash settings now. Good luck.
2answers
When zooming in for a close shot it will not focus
When using the tele, the closest you can be to a object is probably more that one meter. If you need to get closer you should switch to macro mode.
2answers
Can't use macro
Select Macro Mode - this is a fairly obvious first step but I’m always surprised by how many digital camera owners haven’t explored the shooting modes that their camera has. Macro mode is generally symbolized with a little flower and when selected it will tell your camera that you want to focus on a subject closer to your lens than normal (the minimum distance allowed will vary from camera to camera - consult your instruction manual to find yours). Macro mode will also usually tell your camera to choose a large aperture so that your subject is in focus but the background is not.
Read more: http://digital-photography-school.com/macro-photography-tips-for-compact-digital-camera-users#ixzz0KaYY32aZ&C
Jul 07, 2009 • Cameras
9helpful
3answers
I can"t turn on macro. When I push the button, I see on the display that macro is invalid.
I have a Sony W120 and had the same macro problem, tried all the "solutions" mentioned here without result. So I pressed the "Home" button, went to "Settings" (last menu item at right), then "Main Settings", and used the "Initialize" functio. Problem solved !
Can the conventional Maxxum/Dynax flash units be used with this camera?
Yes. The following Minolta dedicated external flash units are compatible with the DiMAGE A1 for automatic flash control: Program Flash 3600HS(D), Program Flash 5600HS(D), *Program Flash 2500(D), Macro Twin Flash 2400*, Macro Ring Flash 1200*. * Program Flash 2500(D) will be available around August, 2003. *Macro Flash Controller is necessary
Top Canon Cameras Experts
old marine
old marine
David Shaub
shadow
Are you a Canon Camera Expert? Answer questions, earn points and help others
