Question about Behringer Pmp4000 Europower 1600-watt 16-channel Powered Mixer Pro Dj Club Stage
Accidently had peaker connect to A side while in bridge mode wud mixer be damaged
Posted by keith hutchens on
Chris Varnam
    New Friend:
  • 24 Answers
Hi, When an two channel (stereo) amplifier is connected in bridge mode the polarity of one channel is reversed, for this example say channel B. An identical (mono) signal is applied to both channel inputs.
The output is now connected between the two channel +ve outputs. As channel A's output goes +ve , channel B's output goes -ve, thus doubling the output voltage.
On this Behringer powered mixer, the bridge switch simply connects the power amp section inputs, the required way.
The bridged output is wired to the B output between pins 1+ and 2+ of the 4 pole Speakon connector. (Because usually pins 1+ and 1- are used, stereo operation is unaffected.)
So.... If you connect a speaker from the A output alone then I would expect it to work, BUT if there is already a speaker connected from the bridge output, then what happens will depend on the amplifier design.
At best the A channel will see too smaller impedance, and hopefully shutdown.
This is a Behringer, it has digital (class D) power amps, and it does Not claim any amplifier protection !!!
If the powered mixer works in normal stereo, then it is probably OK.
If it then does Not work in bridge mode it is likely to be the connector wiring.
All the best.
Posted on May 18, 2014
How do you change from 4 to 8 ohm output on a phonic 1860 mixer
Stereo and bridged mode selects automatically. Stereo mode gives 4-16 ohms per side. Bridged mode is only from 8-16 ohms. This impedance match is created by the combination of speakers you use. If you link any speakers, the wiring is usually going to be in parallel because of the sockets wiring in the cabs. Any time you link 2 speakers in parallel, it cuts the impedance in half. Remember that in bridged mode, do not link 2 8 ohm sets together because this will create a 4 ohm circuit which it will not allow. This can only be done in stereo mode. It is ok to use speaker combinations of higher impedance, but never go lower as it would cause damage to the power amp.
Apr 03, 2013 | Music
Speaker daisy chaining , am I going to damage my amp etc.?
The Peavey CS4080HZ is intended to place 2,040 watts
per channel into four-Ohm-rated speaker
impedances. The "HZ" suffix is intended
to state the amplifier has a relatively high
impedance output and is optimized for no
lower than four-Ohm loads. Are you strapping in Bridged or Stereo Mode? Bridged Mono Operation
Both amplifier channels can be bridged together to make a very powerful single-channel monaural amplifier. Use
extreme caution when operating in the bridged mode; potentially lethal voltage may be present at the output
terminals. To bridge the amplifier, depress the rear panel Bridge switch to the IN position. Direct the signal to channel
A's input and connect the speakers across the hot outputs (the "+" binding posts) of channels A and B. Only channel
A's input attenuator is active while in Bridge Mono mode. Both connectors are strapped together, so either connector
can be used with a patch cable to drive the input of another amplifier.
Unlike the stereo mode, in which one side of each output is at ground, both sides are hot in bridged mode. Channel A's
side is the same polarity as its input with the minimum nominal load impedance being 4 ohms (equivalent to driving
both channels at 2 ohms) in bridged mode. Driving bridged loads of less than 4 ohms will activate the DDT
circuitry, resulting in a loss of power, and may also cause a thermal (overheating) overload.
Therefore, check the impedance of the cabs for each mode. Remember, if you connect two individual speakers in Parallel (+ to + and - to -) you cut the impedance in half. Two 8 ohm speakers in parallel now have a load of 4 ohms. Series connection + to - to + to -, will double the impedance. Two 8 ohm speakers will have a load of 16 ohms.
I have actually taken a two speaker cab with a 4 ohm impedance and opened up the back to re-do the wiring. I rechecked the impedance with a ohm meter. So yes, be careful. Whatever you do, keep the speaker lengths as short as possible. Buy really good speaker wire or if you make your own, go with 10 gauge wire.
May 02, 2017 | Music
How do you switch the behringer 3000 to bridged mode,what settings do you use to get 1200 watts out of it.
Well... you probably won't like this, but here is some info: In bridged mode, a different Speakon to speaker cable is required from only the B... it is wired differently and you can only use one of the plugs. The speaker or speaker system CANNOT be less than 8 ohms in bridged mode... this precludes using speakers in parallel or multiple speakers that are less than 16 ohm impedance... such speakers are NOT commonly available as most are either 4 or 8 ohm. There is a slide switch for bridged mode on the face of the mixer. Next thing you won't like... The 1200 Watts specification is PEAK power, NOT RMS... You can get 400 watts RMS per side USING 4 ohm speakers. If you use 8 ohm speakers, each of those will get 200 watts. I use this mixer myself and ALSO repair them. The voltage swing at the outputs is about +/-60 volts MAX (peak). This is about 40 volts RMS by the time the circuit LOSSES are taken into account. Across a 4 ohm speaker you get 10 amps times the 40 volts or 400 watts. Across an 8 ohm you get 5 amps or 200 watts. The voltage rails in the switching amp are +/-70 volts DC so these are reasonable values. Bridged mode just uses both sides of the amp driven in opposite directions for higher voltage out BUT you have to use no less than a single 8 ohm speaker so there is NO advantage to bridged mode power wise. IF YOU NEED more power, use extra speakers from an additonal amp driven by the 1/4 TRS mains output jacks OR use additonal POWERED speakers driven from the same jacks. Please read my tip about the hazard regarding the SLEEVE of the cahnnel A cable when using Speakon to 1/4 plug cables being the HOT and the tip being the cold for channel A. Ground the sleeve accidentally and goodbye channel A amp...
May 10, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
I accidentally used the two outs (A & B) at turning on the pmp 5000 in the bridge mode. The mixer was normal during the first 10 minutes, then the mixer shut down and stop working, and now it doesn't...
Insufficient information ! Were you using a special cable used for bridged mode or used regular cables and just changed the slide switch to bridged mode? IF you had regular cables for A/B and just had the switch to the bridged mode NO DAMAGE WOULD RESULT. The bridged mode switch really only sets both amps to be driven from the same mixing buss as monaural. If you had a bridged cable and a plain one you would have overloaded one side amp. The amps have an "electronic" over current fuse and if you trip it you have to leave the power off for a minute or so and then re-power the amp. There is a HAZARD that I have written a tip in Fixya about PMP mixers. The sleeve of a 1/4 inch plug connected to side A is the HOT signal out of the amp as opposed to the B channel being the tip of the 1/4 inch plug...this assumes you might be using Speakon to 1/4 inch speaker cables. DO NOT under any circumstances use Speakon to 1/4 inch adapter cables as the barrel of the adapter female part on channel A is HOT to ground and you will pop the A amp.!!!! I am afraid that if you were using regular cables taht another failure occurred not related to the setting to bridged mode. The speaker leads for bridged mode are configured by the way the special bridged mode Speakon cable is wired... The slide switch only configures where the amps get there audio be it stereo busses or singly from one side. If after being off for a few minutes the amp still is totally dead, check the main power fuse which is alongside the power input connection in a plastic boat you pull out. IF THE FUSE IS BLOWN do NOT replace it as it will likely cause additional damage. Have unit repaired. There is a weak spot in these that results in arcing between layers of a multi-layer circuit board.
Apr 15, 2011 | Behringer Europower Pmp5000 Powered Mixer...
We just got a PMP6000 and this has to be the worst manual ever written. Not a word about bridge mode except that it has one. Do I have to rewire a speaker cable or what? Which fader would control the...
Yes, in bridge mode you will wire ONE Speakon that will have the two speaker wires connected to pins "1+" and "2+". You do NOT need the manual to do this, the info is right on the back of the PMP6000 itself. You will plug that Speakon into channel "B".
PLEASE note that you CANNOT go below 8 ohm speaker impedance. If your speakers are 4 ohm you MUST connect two in SERIES which requires special cables and the speakers MUST be identical. You can connect TWO 16 ohm speakers in parallel by daisy chaining, however 16 ohm speakers are NOT very common. With 8 ohm speakers you can connect EXACTLY one in bridged mode UNLESS you connect four of them in series-parallel which requires special cables and great care. Believe me you do NOT want to have an accident with this amp as repairing is extensive.
Lastly, put the speaker configuration switch down to the bridged mode.
This is how bridged mode works: Sliding the switch down basically configures the two power amps in monaural and one amp is inverted so there outputs are out of phase by 180 degrees effectively doubling the voltage.
Remember that BOTH wires in bridged mode are HOT and grounding one while amp is on will likely blow out one side or more.
Mar 27, 2011 | Behringer Europower Pmp5000 Powered Mixer...
No sound from the left side
Assuming your PAN controls are all at 12 o'clock, it looks like you have popped one side of the power amp. Please read my tip on here about the HAZARD on the "A" channel of PMP powered mixers. Essentailly, if you use Speakon to 1/4 inch cables or adapters the BARREL or the SLEEVE of channel "A" connector is the HOT side of the speaker and touch ground with it and goodbye Channel A side amp. They don't tell you about this in the manual. The tip of the plug is e cold side of the amp output UNLIKE channel B where the tip is the hot side. They do this to make it easy to implement "bridged mode".
Reepair of thes amps takes skill. This likely has the DPA300 module in it and you will find one side fried switching transistors and often a Zener diode. Sometimes the circuit board will have arced and be damaged.
Feb 28, 2011 | Behringer Europower Pmp1000 Powered Mixer...
New to the mixer world. i have a dicontinued pmp5000. can't get the bridge mode to work
You require a special cable with the Speakon copnnector wired a special way. Refer to your user manual for the correct pin connections to use bridged mode and then put the slide switch in the position closest to the effects display.
Refer to figure 4.6 on page 10 and figure 4.7 showing the connection for bridge mode.
NOTE: you cannot go below 8 ohm speaker on the bridge mode... that USUALLY means a singl speaker of 8 ohms... you CANNOT parallel two 8 ohm speakers.
The single speaker cable will plug into the "B" output connector. Remember bothe the barrel and the tip of the connector if using 1/4 inch plugs is HOT and grounding either inadvertently will fry the amp.
Jan 19, 2011 | Behringer Europower Pmp5000 Powered Mixer...
If I'am powering 2 Peavey 4 ohm bass binns, then linking, from the base bins, 2 15" 4ohm cabs, should my selector switch be in main L and R mode ,or Bridge mode for maxium output and performance,...
You CANNOT power 4 total 4 ohm speakers from this unit without special configuration. The lowest you can go is 4 ohms per side, which would be one 4 ohm cabinet per side. You would have to do a series parallel arrangement with the resources you have... two Peavey's in series and that combination in parallel with two 15's in series...
This is a VERY unsafe configuration with this mixer. ALSO please read my tip on here in regard to PMP mixer grounding hazard of the A channel when using Speakon to 1/4 inch cables.
Frankly, forget about maximum performance unless you want to risk blowing your mixer...
If I were you, I would put the two 15's in SERIES as 8 ohms on one of the channels and the Peavey's in SERIES as 8 ohms on the other channel.
You would be well to heed this warning as I have repaired a bunch of these units. Be careful of any poor speaker connections as there is an insulation breakdown problem in the power amp circuit board if a speaker becomes intermittent. If something fails DO NOT replace the pwer fuse as you will do more damage.
Nov 18, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Hi, We have recently purchased a Behringer PMP6000/VP1220/VP1220F PA package we have a pair of speckon to 1/4 TS connectors and a pair of 1/4 TS to 1/4 TS connector cables we have the mains on tripods and...
Please read a tip I just posted regarding a hazard of the Speakon to 1/4 inch cables when used with these PMP mixers.
If you are using your main speakers as stereo, then you will need either powered monitor speakers OR an additional seperate amp for them. The mon outputs on the mixer are LINE LEVEL and are not driven by a power amp. Use TRS (balanced) interconnect cables from these to POWERED monitor speakers.
You can parallel your two mains providing the parallel impedance is 4 ohms or greater (two 8 ohms in parallel at most). The the monitor speakers can be paralleled and the switch set to Main/Mon so that one side of the power amp drives the mains and the other drives the monitors.
To prevent damage to the mixer, make sure all speaker leads are secure before powering the system. Run the speaker leads through the handles of the speakers to prevent inadvertent unplugging due to personell tripping over cables.
DO NOT use the bridge mode in your use.
Aug 07, 2010 | Behringer Europower Pmp5000 Powered Mixer...
I am currently having problems with our PA System. We use a Behringer PMP3000 Mixing Board, with a Peavey PV115 Speakers. We can't get them to reach the volume these speakers are ment for. We would run a...
The speakers are 8 ohm so you can probably get near the 400 Watt per side when connected to this mixer. You don't need bridge mode to get this and I would recommend not using it anyway. Whatever you do make sure the speakers don't get disconnected when running at high volumes as you will arc out the amp in the mixer... I know this as I fix them... I have two PMP5000's that I repaired. Lots of work to repair...
The feedback is NOT the fault of the mixer or speakers but instead of something picking up sound from the speakers and sending back to the mixer.
The mic must be well in back of the speakers (say at least 10 feet) to avoid this or you need to use anti-feedback hardware to avoid the problem or highly directional close talking mics. Reverberation off walls can also get back to mics and cause problem. I was able to use a wireless Peavey mic which seemed to disrupt the phase enough to never get into an oscillation even when in front of the speakers.
Apr 18, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer Pmp4000 Europower 1600-watt 16-channel Powered Mixer Pro Dj Club Stage Logo
Top Behringer Audio Players & Recorders Experts
Serge Lavallee
Marty Warge
Marty Warge
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
