SOURCE: Is the frost build-up in my freezer normal?
The drain has most likely frozen over. It is at the bottom behind the back panel inside the freezer. You will need to remove all of the ice and run hot water down the drain until it is clear.
SOURCE: Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
SOURCE: Frost in Chest freezer
Not much you can do except ensure you have a tight seal and not to open it more than you have to.
SOURCE: ice/frost build up inside the freezer
You have a defrost problem. The coils freeze up behind the freezer wall and the air does not flow properly. Replace the heater, defrost timer, and thermostat. get me the model number and i will give you the part numbers so you can order the parts.
SOURCE: frost build up in a frost free freezer
It could be the door gasket. It could also be that the fridge needs a good defrosting. (especially if it is an older fridge)
When I bought my house I had the same problem with the fridge that came with the house. I assumed the previous owner had been defrosting it regularly, which he had not.
Eventually I decided to try a full defrost, and my fridge now works like new.
Hi Dale Dibb, thank you for your inquiry!
I understand that the food inside of your Frigidaire freezer is getting frost on the inside of the packages. I would recommend turning the temperature up inside of your freezer. Additionally moisture inside of the package would cause frost to develop on the inside of the food packages.
Please assure that all possible moisture has been removed out of the food packages prior to placing the items inside of the freezer. If there is anything else that I can help you with, please feel free to reconnect! -Matt
