Question about Kenmore 67082 Electric Dryer
Check lint screen light would always stay on, and can not select any drying modes
4 Related Answers
Anonymous
  • 878 Answers
SOURCE: lint screen
Ledhed, Been doing this for over 25 years and I haven't seen one yet that doesn't catch lint when operating normally., ...Catriver...post back.
Posted on Aug 26, 2006
Anonymous
  • 88 Answers
SOURCE: 3 yr old HE3 dryer - E1 error message
Your thermistor is bad
Posted on Jan 09, 2009
Anonymous
  • 4323 Answers
SOURCE: I HAVE A KENMORE ELITE
Hi
When dryer won't heat or won't turn on or will behave as its behaving with you it means that the Thermal fuse which is located inside duct on the back has gone bad and should be replaced as it cannot be reset. If their is continuity when you check the fuse then it means that the control board is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Dec 14, 2010
Anonymous
  • 4323 Answers
SOURCE: my kenmore elite smart heat
Hi
When dryer won't heat or won't turn on or will behave as its behaving with you it means that the Thermal fuse which is located inside duct on the back has gone bad and should be replaced as it cannot be reset. If their is continuity when you check the fuse then it means that the fuse is fine and there is an issue with the thermostat or thermal cut off. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 02, 2011
Clean lint screen light keeps blinking
The clean lint screen light is just a dummy light. There is no sensor for that.
If it's giving you a AF error then disconnect the vent and run it. If it completes the cycle then it's your vent. If not it's your thermistor.
Sep 30, 2014 | Kenmore Dryers
Error code CL on Kenmore Dryer
The "Check lint screen" light is just a reminder to check the and clean the lint screen before or after each load. There is not a sensor that will detect if it's clean or dirty, it's just a reminder. The "Check lint screen" should turn off as soon as the dryer is started. If it never turns off then the control board would need to be replaced in order for the check lint screen reminder to turn off, however the check ling screen reminder light staying on will not effect the operation of the dryer.
Here is the control board to order.
The part comes with a 365 day, any part, any reason return.
Nov 02, 2012 | Dryers
My LG dle2514w dryer cooling light stays on al the time, and when operating under the "Sensor" dry selection, does not dry, or heat. I can override it and use timed dry, but still, why is this...
underneath the lint trap is the sensor, it is dirty. You will need to clean it, just be gently as if not you may break it, when you look down the lint trap it has two screws.
Feb 19, 2011 | Dryers
Sears HE3 Dryer - "Check Lint Screen" light is on. I cleaned lint screen and area around screen but light will not extinguish and dryer will not turn on. I unplugged dryer for a time and plugged back in...
I am not familiar with your dryer, but it sounds like a safety mechanism where if your lint screen is not cleaned the dryer will not turn on. That "Check Lint Screen" light for your dryer may be connected to a sensor near the lint screen area. Check that out and see if that is the problem. If there is a sensor it could be faulty,
Apr 28, 2010 | Dryers
Model MDE5500AYW. Seems like dryer occasionally overheats when in sensor dry mode. Lint screen and vent are clean and plenty of air flow. One time the sensor works fine (minute timer drops and unit shuts...
there isn't a timer on this machine,you have a control board,if the time isn't counting down correctly sounds like you have a bad control board that's inside the console
Feb 10, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Lint screen light is on, dryer won't start!
If you use dryer sheets they create a wax coating on the lint screen,even tho it looks clean,use dish soap and hot water to remove this,dry it then put it back in and try it.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 30, 2009 | Bosch Nexxt WTMC 6500 Gas Dryer
Dryer Lint Trap Not Catchin Lint
If you have the ability to move your dryer away from the wall and look at the hose located at the bottom of the unit.
1. Take the house off it might be clogged 2. check for ang gaping holes in the lint screen
Jan 19, 2009 | Maytag Performa PAV3200
Check Filer
the clean filter light is just a reminder light.  There is no reset button.  It will always come on when you turn on the unit.
Nov 19, 2007 | LG DLG5988 Gas Dryer
LG DLG 5988 Gas Dryer Does not heat and does not dry
Same problem after 1 year of use. In the past couple of months, the Sensor and Cooling mode light stay on and unit does not dry.
Oct 08, 2007 | LG DLG5988 Gas Dryer
Kenmore 67082 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
