Question about Cuisinart CBT-500 SmartPower Premier Work Top Blender
Cuisinart smart power blender how do i assemble it
3 Related Answers
Anonymous
SOURCE: cuisinart sealing gasket
The gasket goes between the cutting assembly and the glass. So you slip it on over the top of the blades and then put the glass jar over top of that. Screw the bottom cap on to tighten everything together.
Posted on Nov 02, 2007
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: leaking cuisinart smart power 7-speed electronic blender
There is probably a hairline fracture or tiny crack in the blade assembly itself - replace the blade assembly - it will automatically come with a gasket, so you will have an extra.
Posted on Apr 30, 2009
Linda Price
  • 244 Answers
SOURCE: Hi. We have a Cuisinart
This can be coming from discoloration and/or food acting on the rubber gasket. Be sure to take the pitcher apart, removing, the screw on base cap, the blade mechanism,and the gasket to clean your blender after each use. Acids and liquids can act on the rubber causing a discoloration and this will seep into your pitcher. This should take care of your problem. If it does, please come back to Fixya and rate my solution!
Posted on Jul 15, 2011
I have the cuisinart SPB-7 Smart Power and it leaks. I put my milk in and it run on the counter top. What do I need to replace? Is it the washer?
The bottom part that screws on the jug with the blades, either the o-ring is bad,or the screw on piece is cracked and needs to be replaced.
Mar 17, 2011 | Cuisinart SPB-7 SmartPower Work Top...
Misplaced manual. How to assemble Cuisinart Smartpower 7 speed electronic blender- Specifically need to know where to place the gasket.
Hello, W/D here.
You can download your manual here:
http://www.cuisinart.com/manuals.html
It is at the bottom of the page.
On page 4 of the manual is the instructions for assembly of the jar. With the jar upside down, lay the gasket on the threaded area, insert the blade/plate, and screw on the base. Nothing to it.
Best regards, --W/D--
Jan 30, 2011 | Cuisinart CBT-500 SmartPower Premier Work...
I need the replacement glass bowl. My wife dropped and broke. It is the blender bowl for the Cuisinart Smart Power Duet, model FPB-5CH
Hi!!
Smart & Final carries a variety of glass bowls in plastic, glass and metal, at the cost or the S&H you would pay if ordering from dealer.
If helpful, click below.
Apr 08, 2010 | Juicelady JL600 Professional Work Top...
Connection between the motor and the blender unit (where the spinning takes place) - get extremely hot and blender does not seem to blend well. Motor works fine without the top - and the top seems to spin...
Replace the blade assembly immediately. They are available from Cuisinart's website. Sugars and other stuff can gum up the blade assembly over time, so it will periodically need to be replaced. A quick and easy way to keep the blade assembly clean and working longer is to put water and a drop of dishwashing soap in the blender after use and run the blender at low speed for 15-20 seconds - an old Osterizer trick.
Jul 15, 2009 | Cuisinart CBT-500 SmartPower Premier Work...
Leaking cuisinart smart power 7-speed electronic blender
Apr 23, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Cuisinart fpb-5ch blender not working
Remove blender attachment completely, turn machine on and see if it will spin with all attachments removed - if it spins, then replace the blade assembly - parts available from Cuisinart. If it doesn't spin, send to Cuisinart for repair (call first).
Dec 11, 2008 | Blenders
Lights/LED lit up, but blender does not start!
The motor brushes may be in need of replacement.
Sep 09, 2017 | Cuisinart CB-600 Blender
Cuisinart sealing gasket
Aug 15, 2007 | Cuisinart SPB-7 SmartPower Work Top...
Cuisinart CBT-500 SmartPower Premier Work Top Blender Logo
55 people viewed this question
Top Cuisinart Blenders Experts
ThaMp3Doctor
ThaMp3Doctor
Ross Keen
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
