Question about Jl Audio 12W6v2 Car Subwoofer
Why subwoofers pops
The bass stays on while the radio it's on and the car
Posted by Jaime on
I have a dual 1225 I want to know if I can turn off my subwoofers on the radio
unfortunately on this model you cant. but you might can buy a bass control remote for your amp (if your amp has a spot for it) and adjust/turn off your bass with that
Aug 27, 2013 | Car Audio & Video
I have a system installed and i have mtx speakers plus mtx subwoofers i want to know how could i take the bass of the speakers because it sounds horrible when loud
if you turn the bass setting in your radio down it will take the bass out, but may take some of the bass out of the subs as well, if this occurs and you still are not satified, you either have to get a car receiver with a non fading subwoofer preout, or you could get bass blockers for all the speakers you dont want the bass in
Apr 05, 2012 | MTX Car Audio & Video
"pop" in speaker when turned up
more likely your deck is just running out of power. another cause is the speaker leads could be hitting the metal of the car with the bass, check for clearance.
May 19, 2010 | Alpine SPS-609 Car Subwoofer
Bass hits when i play the radio but not when i play a cd
Dont assume because you have set the bass and treble options for your radio that they will work for your cd, press the source button until you come to cd and then set your bass and treble again, hope this works
Dec 19, 2009 | Car Audio & Video
I need to put the subwoofer levels in the radio
go to standby mode. then hold your bass boost button in and the menu should pop up. scroll through until you find th aux setting and use your volume control to set it to on. then the option should be back.
Jun 07, 2009 | Kenwood KDC-MP335 CD Player
I turned my 15" L7 kicker and smoke started to come out the box
As stated before, knowing the impedance of your subwoofer would really help the situation. Either way the link I have provided is to your subwoofers manual (Incase you dont have it)
But since you have said it has smoked, if it still works I recommend turning the bass boost down (Bass boost causes alot of heat within the subwoofers voice coil and even within the amp itself and should never be maxed out.)
Here is a link to your manual for the subwoofer.
http://www.kicker.com/sites/default/files/SoloBaricL7Series.pdf
So as a solution to your issue, keep your bass boost turned down. You should almost never need it if you have tuned your amp correctly (You have a very serious subwoofer there)
Consider yourself lucky if your subwoofer is still working without issues.
Feb 09, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
My tv is making a poping noise. I unpluged the set from the radio but the sound is coming from the speakers on the unit. What is it, and how can it be fixed. Thank you Bryce,
Turn down bass in audio menu or if tv has subwoofer turn down sub level or like i stated earlier turn down bass other than that popping noise is a common complaint with vizio, if under warranty call service provider
c
Sep 29, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Inifinity 1252w subwoofer
this is probably due to the box they are in. it seams that your box is tuned to a lower freq then the bass hits that are popping. message me with the box dimensions and the speaker parameters
May 28, 2008 | Infinity 1250w Car Subwoofer
Jl 12's w3 not all types of basses sound right
zzedly only asked only one good question, here is what should've been asked.
What size is the enclosure?
Sealed or ported?
What frequency is it tuned to if ported?
How much power are you running?
and
What frequency is your LP crossover set to?
Mar 14, 2008 | Jl Audio 12W3 Car Subwoofer
Jl Audio 12W6v2 Car Subwoofer Logo
Top Jl Audio Car Audio & Video Experts
Mike
Vernon Taylor
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
