The CD disk changer is not opening. When i press open, it is not opening instead say "Error". Please help
SOURCE: Sony 5 disk changer disk is stuck not able to open the tray
After some time it was showing some C 31 00 error. I searched on internet, opened the top cover, there is the CD changer and my cd was stuck in there, I pushed the CD from finger and there it goes... on press of eject it came out... thanks anyway...
SOURCE: Our Sony 400 disc changer won't open. I can hear
If ure an expert, then open up the set, check for alignment balancing for the gears and see if the belting has worn out. Pioneer till today uses belt for ejecting. Belt usually the issue.
SOURCE: Our cd changer will not open or play and I need
You need to open your player cover to get your disc ( Please unplug the power prior to do this).
The main problem is on your mechanism system that prevent you open / close the disc tray.
So please check the motor of your mechanism and its gears for malfunction, then get them fixed before retry your player.
Regards
