Question about Champion 3500/4000 Watt Portable Generator
No electric my generator runs but the electric comes out
I have a 4200 generator with a 9hp honda it starts and runs when i try to run a saw it shuts down and backfires
How to test your Electricity Generator AVR Brushes and Alternator on...
You need to run these tests in the video and come back to us with the results. Send your test results to us here: https://www.generatorguru.com/ask-the-guru/
Then we can tell you what the problem is :)
Jun 23, 2018 | Honda Electrical Supplies
I have a pacific 7500 generator that stopped gerating electricity. Motor starts and runs great but no volts coming out
Generating section is no good. Check to see if there is an open circuit breaker in system.
Jan 01, 2016 | Electrical Supplies
Generator engine running but voltage is half of regular 110 volts
With the generator SHUT OFF - and NOT RUNNING, open up the covers and make sure all the electrical wires are connected. It sounds like one of the leads from the alternator has come loose.
Oct 20, 2014 | Electrical Supplies
Over current light
its unlikely its the battery. it will be more like it is running too fast for some reason. i would contact generac for advice. or join the forums at ziller electric .com
Dec 28, 2017 | Electrical Supplies
My 3000 watt Duracell inverter will not start a 1 1/2 hp electric motor. The voltage drops to 45v and the electric motor struggles to reach full rpm. This is a table saw with no load. The generator revs...
have the saw motor checked for internal and wiring problems
check the start/run capacitor of the electric motor
running a 1 1/2 hp motor (1075 watts) on a generator that has a running wattage of around 2250 watts means that it should start and come to speed immediately if the motor is good
the problem indicates that there is a circuit problem in the saw motor that is exceeding the available wattage (3000 watts ) on start up
Oct 22, 2017 | Duracell DS30R1i 3000 Watt Continuous...
Hook up electrical cord and run a TV, Fan, and it burns up the load (TV, fan, etc.).
Check what your voltage / frequency is coming out if the unit, generator outlets.
Jul 12, 2011 | Coleman Powermate Premium Plus 6250W...
With my generator running i have ac power but my ac does not come on
Make sure your generator is rated high enough to run you a/c. Also is you a/c 120v or 240v? Do you have it plugged into the right voltage?
May 08, 2010 | Yamaha 4500 Watt Electric Start Generator...
Engine runs but won't generate any electricity
Sometimes the generator loses the magnetic field that allows it to produce power. Do a Google search on "flashing a generator field". There are many ways to do it, but I would recommend doing some reading before trying it. Your "dead" generator could produce hazardous voltage once it comes back to life.
Also, before trying any of this, make sure the circuit breakers on the generator (if equipped) are not tripped.
Good luck and be careful!
Jan 19, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Champion 3500/4000 Watt Portable Generator Logo
129 people viewed this question
Top Champion Televison & Video Experts
Lee Hodgson
Lee Hodgson
Harrie
Are you a Champion Televison and Video Expert? Answer questions, earn points and help others
