Question about Kenmore 67082 Electric Dryer
Will not start
Turned on for second then shut off
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
Aspire ahows green light but won't start up, have turned off main but still just green shows
Pull the plug from the AC outlet, wait a 30 seconds, plug in, try to reboot. Does it try to start and in a few seconds shut down? Give as much detail as you can.
Dec 19, 2012 | Acer Aspireā„¢ T135 PC Desktop
My 1993 nissan sentra 1.6 wont run and check engine light wont turn on,bulb is ok
Could be any of several things. If the crank sensor is marginal and not sending pulses, the fuel pump is shut off. This is for safety. The pump is energized for a few seconds as key is turned in preparation for starting then engine must rotate normally to keep the pump on. If it stops, in a few seconds the fuel is cut off.
Aug 17, 2012 | 1993 Nissan Sentra 4 Door
Fuel pump comes on then it suddenly shuts off
Your fuel pump is suppose to come on for 2 seconds when the ignition switch is turned on then it shuts off inless the engine starts.
Jan 31, 2012 | Cars & Trucks
My car starts and shuts off after 3-5 seconds.
with key in ON position can you hear the fuel pump humming uder the middle of car? the pump should hum for about 10 to 15 seconds,then go off and come back on when the key is turned off and then key turned back on.could possibly be a bad fuel filter, or a fuel pump going bad, it's definitly a fuel issue because it starts. try replacing the most inexpensive thing 1st. the fuel filter and then the fuel pump. hope this helps!!!
Nov 11, 2010 | 1995 Chevrolet Camaro
The Television will not stay on
LOOKS LIKE YOUR CONVEGENCE IC ARE SHORT UNWELD BOTH IC AND TURN TV ON IF IT STAYS ON 450 DOLLASR TO REPAIR
Jun 03, 2010 | Hitachi 43F300 43" Rear Projection...
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
1997 S10 pickup starts then shuts off in 2-4 seconds
fuel filter could have picked up garbage in the tank
Nov 11, 2008 | 1997 Chevrolet S-10 Pickup
Laptop keeps shutting down, both fans not working
sounds like you have a bad motherboard, or uP...is this under warranty, by chance?
May 25, 2008 | Dell Latitude C640 Notebook
Kenmore 67082 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
