Question about Danby DBC162BLSST | Silhouette Select 5.3 cu.ft. Capacity Built-In Beverage Center
Machine is building up frost inside. - Danby DBC162BLSST | Silhouette Select 5.3 cu.ft. Capacity Built-In Beverage Center
How do you make a freezer frost free?
Frost free means that the evaporator coil will not accumulate a thick layer of frost. It will not prevent frost from accumulating on the walls of the freezer. To slow down the amount of frost build up inside the freezer, do not keep the freezer door open for any longer than necessary. The freezer door seal may be defective. This would allow moisture in that would freeze on the inside walls. A heater with timed intervals to come on is one way for a frost free feature. But this will not work for frost build up on the inside walls of the freezer. It would only melt the frost and then it would refreeze again.
Aug 31, 2015 | Frost Freezers
Why is there a continuous frost build up on the outside of the filter of my 70 pt dehumidifier.?
frost on the coils of a machine is an indicator of low air flow across the coils ,and also a decrease in the gas charge inside the machine , the first usually causes the second , due to increase in heat build up , its gotta expand and vent to someplace when it gets hot
May 18, 2015 | Soleus Dehumidifiers
Why do I have ice build up in my freezer
Ice build on the freezer box floor or White frost build up on the freezer box back wall (inside). Ice layer on floor means your drain line blocked. White frost layer means your machine is not going into defrost cycle.
Oct 07, 2014 | Whirlpool Refrigerators
Our Frigidaire frost frost free upright freezer from day one has frost build up on the food inside the packages. The frost is not a problem in the freezer itself, but on the food. Freezer burn occur
Hi Dale Dibb, thank you for your inquiry!
I understand that the food inside of your Frigidaire freezer is getting frost on the inside of the packages. I would recommend turning the temperature up inside of your freezer. Additionally moisture inside of the package would cause frost to develop on the inside of the food packages.
Please assure that all possible moisture has been removed out of the food packages prior to placing the items inside of the freezer. If there is anything else that I can help you with, please feel free to reconnect! -Matt
Sep 30, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The contents of the refrigerator freeze even on low settings
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Aug 17, 2011 | Refrigerators
Freezer is working fine but the fridge is not getting cold
Hi mattwhodges,
This issue is usually cause bya defrost problem. First thing that you need to check is the freezer area.Please look at the back panel inside the freezer. If you notice a frostcovering at the back panel, you have a defrost problem. The only part inside the wholerefrigerator that "get cold" are the coils inside the Freezer. Thecoils need to stay free from excess frost build up so that air can pass throughthe coils and will reach the refrigerator section. The compressor and fans willshut off and machine will go into defrost mode every eight hours or dependingon the type of defrost timer or control you have. When the refrigerator is indefrost there is a heater that is tied into the evaporator coils inside thefreezer that comes on. This heater is behind the rear panel inside the freezerwhere the evaporator coils are located. It melts the frost that has accumulatedover the course of time. After about thirty minutes the machine comes out ofdefrost and goes back to normal operation. The first thing that you cando to get the machine running is to remove the rear panel of the freezer.Please remove all the frost ice that has built up. The best method is to pourhot water over the coils. The water will drain out the freezer through thedrain hole in the bottom of the freezer under the evaporator coils. Once all the frost is gone,you could put the machine back together and it would work fine. For a few days,until the frost has developed again due to the defrost issue. That would onlybe a temporary fix. Hope it helps. Thank you for using FixYa.
Feb 01, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker works, fills door but doesn't come out
You have a bad dispensor flap solenoid . Frost due to flap not closing completely and ice will catch in the shoot .
Jul 25, 2009 | Whirlpool GS6SHAXLS Side by Side...
Frost buildup on area where ice comes out of the ice bin with frost also on the inside of door chute
The flap door where ice is dispensed is warped letting warm air into the freezer causing the frost build up. You must replace the flapper - a $5 - $7 part but not too difficult to replace. I find the flapper last only about 2 years and frost problem reappears. Forget about a "weak heater".
Jul 08, 2009 | Whirlpool GS6NBEXR Side by Side...
Excessive frost build up inside the freezer
Your problem is not a recall it is the fan and how many items you have in your freezer. Is it stuffed pretty full?
Jun 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
Frost building up inside freezer.
Hi: Make sure your vents are not blocked by too much product in the freezer. When you changed the heater did you take a hair dryer to the back to make sure the initial blockage of frost and ice was removed as that will still block the air flow to the referigator, and cause frost to build? Also if the frost isn't in the back of the freezer but on the food it means there is a bad door seal. Usually the frost will look like snow flakes. The timers are on a circuit board now. And expensive. Ge makes an excellent refrigerator, but the parts are high in price. I hoped this helped. Jeff
May 31, 2009 | GE GSS23QSSS
Danby DBC162BLSST | Silhouette Select 5.3 cu.ft. Capacity Built-In Beverage Center Logo
Top Danby Furniture Experts
Dennis Boxerman
jdthefixer
jasbo
jasbo
Are you a Danby Furniture Expert? Answer questions, earn points and help others
