Epson AcuLaser C900 Printer Logo
Question about Epson AcuLaser C900 Printer
Printed image is moved down the page
Pages are printed with the image moved approximately 20mm down the page
5 Related Answers
Anonymous
  • 110 Answers
SOURCE: Epson LQ-2180 continuous printing problem
An Emulation driver will fix everyones problem... Do this:
1. Click on "Start", then "Control Panel" and then "Printers and Faxes".
2. In the left hand column choose the option "Add Printer". The "Add Printer Wizard" comes up, click on "Next".
3. At the "Local or Network Printer" screen choose "Local" and remove the check from "Automatically Detect".
4. Click on "Next".
5. At the "Select Port" screen choose the appropriate port (usually LPT1: recommended printer port).
6. At the install printer software screen choose "Epson" under "Manufacturer" and LQ-1050 for the printer, then click "Next". If you wanted to install the Windows universal driver, choose "generic" under "Manufacturer" and choose "Text Only", then click "Next".
7. At the printer name screen choose "Next".
8. When asked if you would like the printer to be default make the appropriate selections and then click "Next".
9. Finally click on "Finish". You may need your Windows XP installation disk.
Posted on Aug 22, 2008
Anonymous
SOURCE: DFX 9000 Printing problem
when i switched on epson dfx9000 printer its showing Error 01,Pls give the solution.
Posted on Jan 17, 2009
Anonymous
  • 163 Answers
SOURCE: Ghost image on Epson Acculaser C4000
Ghosting can be caused by several components: 2nd BTR transfer roller, Photoconductor Unit (PCU) or the Fuser unit. The most likely is the PCU contacts being dirty, caused by toner getting between them. Open the front of the printer (cover B) and lift out the photoconductor. Clean all of the metal contacts down the sides of the PCU with a cloth and wipe out any loose toner from inside the printer and give the contacts inside the printer on the R/H side a good clean. Replace the PCU and close the front cover.
Hopefully all will now be well, if not open cover A and clean the transfer roller on the inside of the cover. If problem persists you will need to get a Tech out to look further as without seeing the printer it is pretty hard to diagnose.
Good luck.
Posted on May 20, 2009
Anonymous
  • 63 Answers
SOURCE: the printer only prints half a page then moves to next page and a
Before printing, the printer checks the paper size. If the paper edge guide is positioned incorrectly, the paper may be fed at an angle. If this happens, the bottom of the paper is therefore at an angle and not perpendicular with the paper feed rollers. This can result in the paper sensor not recognising the real page width as it can only detect a certain amount of the bottom of the paper sheet which is nearest to it.
If only part of the width of the paper is detected, the printer considers that the paper width is less than it actually is. To avoid printing on internal parts of the printer such as paper feed rollers, the printer automatically cuts the image to fit the detected paper width As this phenomenon depends on the paper feeding condition, it can be random.
Reload the paper and make sure it is loaded correctly. All the way to the right and the paper guide correctly adjusted.
Posted on Feb 10, 2010
Testimonial: "Thank you so much, I no longer have a problem. It seems such a simple solution now I know the answer! I thought it was something major."
Anonymous
  • 5 Answers
The default paper height is 12". If you want to change it to 11" you should refer to printer manual and follow the steps. Otherwise if you are using a software for printing. Ask your developer to give following command for setting paper height
Chr(27) + Chr(67) + Chr(0) + Chr(11)
Posted on Mar 25, 2010
1helpful
How to print from the internet to my computer in google chrome win7
You can save web pages from Google Chrome to your computer, just as you can print pages on a printer.
To save web pages in HTML format: Click on the wrench icon in the Chrome menu bar (upper right corner), pull down the menu and select "Save page as". (Or alternatively, right-click on page and select "Save page as"; or use the keyboard shortcut "Ctrl + S"). Then proceed to save the page as "webpage complete" (which will include images), or as "HTML only" (which will include text but not images).
To save web pages as PDF files: Click on the wrench icon, pull down the menu and select "Print". (Or alternatively, use the keyboard shortcut "Ctrl + P"). Then on the print page, pull down the "Destination" menu, select "Print to PDF", then click the "Print" button. You can then save the page as a PDF file.
See also, this guide to printing web pages from CNET:
http://howto.cnet.com/8301-11310_39-20111396-285/five-ways-to-save-a-web-page/
Hope that's helpful.
6helpful
2answers
Ghost printing
You have a worn image drum. The drum is the part of the printer that the print image is created on before it transfers the toner to the paper. This part is coated with a very thin layer of Teflon so the toner does not stick. When it gets worn the toner starts to stick and that produces the shadow or ghost image approximately 3 inches down the page because the diameter of the drum roller is 3 inches. You will need to get the part DR-350, Office Depot has them as well as many places on the internet.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
Samsung MFC-SF560 fax not printing complete page
If you have already try another image unit, you should try to make a copy or print a report. If the prints came out ok, the problem could be the telephone line. GOOD LUCK.
Text moves down the page when I copy - how can I stop this?
Sounds like it is either resizing the image or not seeing all of the original.
Specify the original size and do not use auto.
Make sure thsat image shift or image centring is not on.
Image move toward 3/4 of page down ..... no idea what happens
hi,
unexpected page size is normlay caused by the client PC being set to either A4 or letter when it was expecting somthing else.
try and change your client to the correct paper size.
regards
Matt
2helpful
2answers
Okidata c3200 - "needs new drums" message
Check your page count, drum life on a C3200 is roughly 15000 pages. This information can be found on the information menu map.
Information Menu ecblank.gif ecblank.gif dot.gif ecblank.gif Menu Item Default Setting PRINT MENU MAP EXECUTE Prints the MenuMap (menu listing) with current settings shown. Information about your printer is also
shown at the top of each MenuMap page.
Life Expectancy ecblank.gif ecblank.gif dot.gif ecblank.gifToner Cartridge
Life expectancy approximately 1,500 pages, assuming about 5% coverage, which means that 5% of the addressable dots in an image are printed with this color of toner. See Toner Cartridge..
Image Drum
Life expectancy approximately 15,000 pages, assuming an average of 3 pages per print job. If the average print job is longer than this, the image drums could last longer, but if the average print job is shorter, then image drums will be used more quickly. See Image Drum.
Transfer Belt
Life expectancy about 50,000 letter-size pages. See Transfer Belt.
Fuser
Life expectancy about 45,000 letter-size pages. See Fuser.
Printer ignores white space at beginning of document
by dragging the black bar on the left with your mouse when
the cursor changes for resize
2answers
White line across printed page
Hi Alms, Is there any chance you can post a scan of one of your faulty pages. This would help to assess the fault. If you print several pages, does the image move further and further down the page with each copy? Is the white band repeated down the page? If so measure the distance between each band - this will help identify the faulty component.
Top Epson Office Equipment & Supplies Experts
Mehandi Husain ...
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
