Question about Copystar CS-1500 Copier
Copystar cs-1500 fuser temperature problems
I have a Copystar CS-1500 copier in the field for 3 years  with just 3,800 copies on it which gave me a c-6020 code. I reset the fuser code "Simulation 163" which reset copier fine. Later it gave the same code so I ran simulation code again then ran Sim 199 to watch the fuser temperature.
It varied the high temperature from 187 to 234 degrees. I then reset the temperatures with Sim 161 to "135, 145, 170, & 175" and the temperature stayed under 230 degree but sometimes gives c-6000 code ( too low temp)  .
I have replaced the Thermistor and also the Power Source pcb but still have varying high temperature. I also did clear ram code and reset to Inch mode but still have problem. Please help if you can
Thank you in advance,
Dan Howard
[email protected]
Posted by WOS Dan on
Anonymous
  • 65 Answers
Sir have you changed the heat roller, during the replacement of your thermistor?
Posted on Dec 06, 2008
Sam
  • 36 Answers
I had the same problem. And after spending as much time as you have. I replaced the fuser assembly. Problem solved.
It's not that expensive and how much is your time worth?
The hot line suggested I replace the main board and the intermitant board between the two. .......I still have them.
Posted on Nov 01, 2007
E 6000
6000 error. Broken fuser heater lamp wire The fuser temperature does not rise after the fuser heater lamp has been turned on
Nov 12, 2013 | Kyocera Copystar CS-1820 Black and White...
Where can I get a drum for a copystar cs1510?
http://www.digitalsystemcopiers.com/Copystar_CS-1510specs.html
About Us How to Order
Warranty
Contact Us
Email
CopyStar CS-1510 Digital Copier
CopyStar CS-1510 Digital Copier Supply Prices Toner Type Cartridge: Price: $37 Yield:7000 Developer $54.00 per 100,000 copies Drum $107 per 100,000 copies
CopyStar CS-1510 Digital Copier Optional Equipment
Oct 22, 2011 | Office Equipment & Supplies
Need Manual for Copystar CS 1510
Use the link below to download the manual from the maufactures website. The link is for the KM-1510 which is the same as the CS-1510.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=5051&rid=2076
Apr 29, 2011 | Copystar CS-1510 Copier
Copystar CS1510 Error E70
Your fuser needs to be replaced
Apr 28, 2010 | Copystar CS-1510 Copier
Hi I have a copystar CS 1810 and it started to make a loud clicking noise and now I have a code showing on the display 620 and C. Can you help Thank you, John
Hello sir; It's a fuser problem, but you need to reset, the procedure as follow; Press and holding down following keys in order, "stop/reset", "start", and "left copy density", then press "stop/reset" key again, then enter U63 press "start", window will display "CLE", press start again to clear.
Oct 27, 2009 | Copystar CS-1810 Copier
I am getting an error code on my CS-1500 that says C-6 then 020. Unplugging and restarting do no good. Any idea what's wrong? Tom
That is a HIGH temperature detect error code.
Check the thermistor, if you measure 0 ohm resistance in the thermistor, replace it.
Press the stop/clear key, start key
and the left copy exposure adjustment
key in the order presented and hold
them down.
Press the stop/clear key.
Enter the number of the maintenance
item to be executed using the copy
exposure adjustment keys or the zoom
+/- keys.
Go to U163 and hit the Start Key, this will reset the trouble code.
Sep 11, 2009 | Copystar CS-1500 Copier
Kyocera cs 1820 or copystar = error message = 3200
3200 is a problem with the exposure lamp. If you are in a dirty enviroment, the problem could be dirty mirrors under the scanner glass.
Apr 02, 2009 | Kyocera Copystar CS-1820 Black and White...
Have a copy star copier and is showing Error c-6
on the key pad dial in 1087 1087 enter. then type in 163 enter and the thermistor error should go away
Dec 14, 2008 | Copystar CS-1500 Copier
Copystar CS-1500 Copier Problem
Did you remove the drum unit when fitting the toner? Try reseating it.
Nov 25, 2008 | Copystar CS-1500 Copier
Copystar CS-1500 Copier Logo
281 people viewed this question
Top Copystar Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tammie Duggan
Tammie Duggan
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
