Question about Denon AVR-E400
Cont get any sound out of the rear speakers on my avr e400
1 Related Answer
Anonymous
  • 93 Answers
SOURCE: Denon AVR 2807 with Bose Acoustimass 15
Well,i can tell you are not very focus,cause you posted Denon AVR-2807 with Bose AC 15 problem,but under your details,you put down AVR-5807!
First of all,it is so unfortunate that you are NOT able to gain and experience to true ability in sound for this wonderful receiver when you are using a dual tweeters speakers and expect to have good sound separation as a TWO WAY speakers(a tweeter and a midrange-for true high frequency and mid frequency sound separation.)
Secondly,you have defeated the audio configuration of the Denon AVR-2807,since all your speakers are control BY the Bose subwoofer.
Now,i could show you a way to hook this up,and it doesn't matter how you connect them, they are the "bicycle tires" installed with a "Porche"engine if you know what i mean.
If you want a good recommendation for your "beast",i will more than happy to show you the way!
Cheers,
solutiondoct
Posted on Nov 06, 2008
While watching TV or even when all components (except the Denon receiver) I hear random noises through speakers. What could be causing this?
Your problem could be a bad dsp processor which is on the hdmi pcb, change that pcb and the problem should quit
Apr 04, 2015 | Denon AVR-E400
How do i get all 5 speakers to work? only the three front ones work not two in back
Check the source, is it a surround sound source? If not, you'll need to change it to a 5/7 channel stereo setting, probably under the music option. Most music is only stereo, because we only have two ears!
Jan 27, 2015 | Denon AVR-E400 - 7.1 Network Home Theater...
How do I get HDMI cables to sync or talk to each other. We had this problem when we hooked up an Apple TV box to a Denon AVR-E400 and our Sony HD TV. We were told to disconnect all HDMI cables unplug
Personally I would use an RCA cable and hook up the AVR.
((RCA out of TV to AVR audio in))
((cable box HDMI cable output to TV HDMI Input1))
(As far as the AppleTv I would use a separate HDMI Input2)
If your AVR has a dvd or blue ray player Hook up a
HDMI cable out to another Input HDMI3 of the TV
using separate inputs on the tv will allow your surround system to be
used on all modes(CABLE,DVD/BLUERAY,APPLETV)
Sep 27, 2014 | Denon AVR-E400
Only two speakers work on playback
do you have it in surround mode?
Apr 16, 2014 | Denon AVR-E400
My AVR-E400 sub woffer not working through the Denton system
AVR-E400 has an RCA subwoofer output. This is a line level signal that must be connected to an ACTIVE subwoffer (has its own power amplifier) Also the source must contain subwoffer signal (5.1, 7.1, 9.1 surround sound etc) You will not get subwoffer signal from a stereo source such as audio CD, non-dolby type TV etc. Cheers, Don.
Dec 05, 2013 | Denon Audio Players & Recorders
Denon AVR-1706 Left Front and Rear speakers stopped working. Any suggestions?
go into the settings menu and do a sound test using the recievers pink noise tester to test each speaker connected, if while doing this test you still get no sound from those two speakers check connections, make sure speakers are not blown.
if speakers and connections are good then the reciever needs repair
Jul 18, 2009 | Denon AVR-1706 Receiver
Cheers,
solutiondoct
Sep 28, 2008 | Denon AVR-2807 Receiver
Cant get rear speakers to Work AVR 745 7.2 Surround!!!
Another way to solve this rear speakers problems is to go to the equalizer and have the system recognizes the sound coming out of all speakers. The AVR 745 comes with a microphone on the stick, using that to run the manual equalizer. It is the manual equalizer will set the rear speakers.
Dec 29, 2007 | Harman Multimedia AVR 745 Receiver
Denon AVR-E400 Logo
49 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
