Hi Alex Hamilton, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Trying to show a date and time display on my digital camera when i'm taking pictures. I have a finepix T410Hi Alex Hamilton, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
Fuji Master
Re:
The date and time appear in the lower-left corner of the screen, both when taking pictures and when reviewing pictures you've already taken.
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
If you have forgotten to set date and time then you can also set date and time after turned on the camera. to set date and time follow the given instructions:
Press the Menu button on the rear of the device, then choose Set with left or right button, Then go to Setup menu.
Select Option followed by time icon. This brings up the date display. The display blinks as it has not yet been set.
With the help of Right or left buttons select Year, Month, Day,Hour or Minute. Then press Menu/Ok button after the settings completed. Now every picture captured with the Fujifilm FinePix F460 will save the date and time to the pictures
I hope this solution helps you For further assistance, I am here to help. Thanks and Keep Visiting FixYa
The Fuji FinePix S1000FD camera supports time stamping only when printing pictures via USB with a printer that supports PictBridge. Otherwise, you will need to download the images and use an application such as "Visua Photo Time Stamp."
To print with PictBridge,
Connect the camera to the printer and make sure the printer is on.
Press the right-pointing arrow and hold for a second or until the USB logo is displayed on the camera
Press the DISP/BACK button on the camera
On the menu, select the PRINT WITH DATE option and press MENU/OK.
Hello and Welcome To set the date and time stamp on pictures, Follow the given instructions:
Power on the FUJIFILM FinePix J28 digital camera and wait for the hardware to finish running through its start mode
Press the "Menu" button on the rear of the device, then choose "Setup."
Select "Options," followed by "Date." This brings up the date display. The display blinks as it has not yet been set.
Push the top button on the control display to advance the first number
in the date. Once you have the correct number selected press "Enter" and
repeat the process for all the numbers. When the date is set the time
information appears. Follow the same procedure to set the time. Press
"Enter" to accept the changes. Now every picture captured with the FUJIFILM FinePix J28 will save the date and time to the pictures
do you have strong enough batteries in it? I used to try the cheap ones in mine but they wouldn't work any better than that, I started buying the energizer rechargeables.
Set date and time and camera should work. If camera asks to have date set everytime you take batteries out then the memory 3 volt battery is flat ... replace.
