Question about HEWLETT-PACKARD Envy 5530 built-in WiFi HP Thermal Inkjet eAll-in-One Color Printer
Door is open
Prints test page but not from printer
Posted by Tamara Maxwell on
syed jabir ali
    New Friend:
  • 110 Answers
Please download and run HP Print and Scan Doctor from www.hp.com/go/tools
Regards,
Posted on Apr 23, 2014
Installed new ink. it says out of alenment
Dennis: According to an old FixYa.com, urbanhookupz said: "You need to run a printer alignment page like you do when you put in new cartridges.
unplug your printer plug it back in.
open door and take out print ink cartridges.
put them back in and then close the door.
It should now prompt you to do a test alignment page.
now try and print it should solve the problem.
if it does not prompt you to do a test page
Aligning the Print Head
This operation must be carried out when using the printer for the first time.
Aligning the
Print Head positions allows you to print without shifts in the color registration.
Print head alignment is performed either automatically or manually. This section deals with
automatic Print Head alignment only.
?? Ensure that the Inner Cover is closed.
?? The Print Head can also be aligned from the printer itself.
1.With the printer on, load a sheet of Letter-sized plain paper in the Sheet
Feeder.
2. Hold down the RESUME/CANCEL button until the POWER lamp flashes four
times.
1 With the printer on, load a sheet of Letter-sized plain paper in the Sheet
Feeder.
2 Open the Printer Properties dialog box.
See "Opening the Printer Properties Dialog Box Directly from the Start Menu" on
page 28.
3 Print the pattern.
(1) Click the Maintenance tab.
(2) Click Print Head Alignment."
May 26, 2015 | Canon MX340 AllInOne InkJet Printer
Friend has P2014. Will print test page perfectly. Will not print normal output, message claims 'Door Not Shut'. All doors appear shut. Drivers reinstalled.
Open left door,find right upper side door swich location, remove door swith wires connectors & connect them directly then try for print if its printing well,check door switch/mechanism
Sep 19, 2011 | HP LaserJet P2014 Printer
Hello, my problem is that my laserjet printer p1005 doesnt print anything.. whenever i command it from my pc it doesnt do anything.. i tried changing cartridge but still same prob.... please helllppp...
First, print an Engine Test Page.
To print an Engine Test Page, open and close the cartridge door five times while the printer is in ready mode. The printer should print one page with multiple horizontal lines.
If the engine test page printed, is a comunication problem (PC configuration,PC/Printer conection/Driver bad installed)
Jul 18, 2011 | HP LASERJET P1005 Printer
My HP 2420 had a paper jam. I played around with it and must have cleared the path although I did not see any paper particles fall out. (I did have a jam and figured a small piece must have been left...
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Oct 15, 2010 | HP LaserJet 2420 Printer
Prints one or to pages then stops. Have to reset computer to get it to work. No test doesn't work. It is like it runs out of memory.
Try to run a test for continuous print test page in diagnostics mode. To enter the Diagnostics mode:
1. Turn off the printer.
2. Open the front access door.
3. Turn on the printer while pressing and holding Cancel .
4. Close the front access door once the Error light displays. Print the menu page by pressing and holding Continue until all of the lights flash. Follow the instructions on
the menu page to access the menu items.
Continuously print pages containing cross lines, printer information, and margin settings. Press and hold until the Continue button lights flash to begin. Press Cancel to stop.
Make sure he selects the "Cont Prt Simplex Tray 1" option
If problem persists, contact Lexmark at 1-800-LEXMARK()1-800-539-6275.
Apr 21, 2010 | Lexmark E260dn Laser Printer
Printing is offset
you need to run a printer alignment page like you do when you put in new cartridges.
Aligning the
􀁺 Ensure that the Inner Cover is closed.
􀁺 The Print Head can also be aligned from the printer itself.
Feeder.
times.
Feeder.
See “Opening the Printer Properties Dialog Box Directly from the Start Menu” on
page 28.
remember if my answer was of assistance please leave a positive rating and a testimonial.. THanks Good luck
Mar 28, 2010 | Canon Pixma iP3000 All-In-One InkJet...
Samsung CLP-315W Color Laser Printer will print only half page
http://www.fixya.com/support/t3934542-exit_sensor_problem_samsung_clp_315
Mar 23, 2010 | Samsung CLP-315W Laser Color Printer
I try to print a card or bank statements and nothing is printing just put in new ink, it only prints the 1st page of a quarter fold card, it should all be on one page and it prints only partial card
IF the Kodak AiO printer is printing partial ther are two main device of the printer that have issue on the scanner [where you put the document for copying] or the printhead of the printer.
Step that you can do
1. Try to print a test page in this way you can check if the printer prints whole page. How to print test page press copy button and photo button on the printer for atleast 10 sec. or until the printer starts printing. Reminder Test page doesn't need a document on the scanner glass. It will print an advertising doc for the printer. Now if the test page is half/partial it is the printhead that has an issue. If it print the whole page it is the scanner that has issue contact kodak for printer repair
2.Clean the printhead twice and reseat the printhead it
How: press menu button then select clean printhead then select basic/deep clean. To reseat printhead open the printer access door; remove the ink cartridges; remove the printhead; close the printer access door then open the printer access door insert the printhead then the ink cartridges.
3. Try to print again [For futher support call Kodak support line at 1 800 421 6699]
Nov 21, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Door Open
i would start by looking at the door sensor can't be closing fully hope this helps regards Jim
Apr 28, 2009 | Dell 1320c Laser Printer
Test page print before all new printsession
Thank u very much indeed. I took out the cartridges after opening the front door. and reslotted the same int their positions. The printer as usual printed the test page. I put the said printed test page in the top tray of the printer closed the lid and as advised pressed the start scan button on the printer. this started the scan and when the process was done the printer stopped blinking. I switched off the printer and the next session with the printer was trouble free. Dr. bhawnani.
Apr 28, 2008 | HP PSC 1510 All-In-One InkJet Printer
HEWLETT-PACKARD Envy 5530 built-in WiFi HP Thermal Inkjet eAll-in-One Color Printer Logo
54 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Harrie
Duke Bells
George Mclaughlin
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
