Archos ARNOVA 10 Android Tablet Logo
n
niyana coles Posted on Apr 06, 2014
Forgot google account ussername and password
What should I do and it is not letting me master reset the down volume do work **** it wont let me scroll down to reset it so I was wondering was there some kind of secret username or password to reset your tablet thank you.
bozrah
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Apr 07, 2014
bozrah
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
6468
Points
70
Your title of the question says u lost your google user+pass? but the description talk about something else i notice, but to fix the google issue go to google to sign in then click FORGOT PASSWORD or USERNAME then u put in your email address and go from their, this will get you back into your google account, if the pad not working use another PC to do this. If the pad won't work google how to do system restore on ANDROID 10, or find the manual for your model and read how to do this. If you can get in i'd backup any important files first...save favourites/bookmarks if u need to or any profiles, as u may loose all apps and have to reinstall worst case...
How do you get a passcode off a prestige elite 8 QI tablet?
If you forgot the passcode to unlock your Prestige Elite 8QI tablet, you can try the following methods:
  1. Use Google account: If your tablet is linked to a Google account, you can try to unlock it using the associated Google account credentials. On the lock screen, tap "Forgot Pattern" or "Forgot Password" and follow the instructions to enter your Google account username and password.
  2. Factory reset: If the above method doesn't work, you can perform a factory reset on your tablet to remove the passcode. Please note that this will erase all data on your tablet, so make sure to back up your files before proceeding.
To factory reset your Prestige Elite 8QI tablet, follow these steps:
  • Power off your tablet.
  • Press and hold the Volume Up button and the Power button at the same time until the logo screen appears.
  • Release the Power button but continue holding the Volume Up button until the Android System Recovery menu appears.
  • Use the Volume buttons to navigate to "Wipe data/factory reset" and press the Power button to select it.
  • Use the Volume buttons to navigate to "Yes -- delete all user data" and press the Power button to confirm.
  • Once the reset process is complete, use the Volume buttons to navigate to "Reboot system now" and press the Power button to restart your tablet.
Your Prestige Elite 8QI tablet should now be unlocked and ready to use.
T47B Tablet how to unlock screen forgot code
Hi Mate,
  • On the unlock screen, enter your unlock pattern
  • After five attempts you'll be asked to wait for 30 seconds. Tap OK
  • If your phone display goes off, tap the power button and unlock your screen
  • Tap Forgot pattern? If you haven't set up a Google account you won't get this option, instead you'll need to reset your tablet
  • Enter the username and password of your Google account, tap Sign in
  • You'll be asked to create a new screen unlock pattern. If you don't want one, tap Cancel
To reset your tablet:
  1. Turn your tablet off
  2. Hold the volume down key
  3. Turn your tablet on
  4. Using the volume down key, highlight Wipe data/factory reset and press the power key to select
  5. Press the volume up key
  6. The reset is now complete.
Note: Resetting your tablet will clear all the data stored, data that's stored on your SIM is safe.
Cheers!!
2answers
I cannot remember my password to get into my tablet
hi John.
i think you will have to do a hard reset to sort this out.
Just tap the Power button to select Reboot System Now.
  1. Make sure tablet is powered off.
  2. Hold down Volume + button and Power button at same time.
  3. When screen comes on let go of Power button.
  4. When the large Android shows on screen let go of Volume + button.
  5. Use Volume - button to scroll to Wipe Data/ Factory Reset.
More items...
What do I do if I forgot my password to unlock to my tablet? - Trio ...
https://support.triotablets.com/.../201746559-What-do-I-do-if-I-forgot-my-password-to-...
How do I unlock my tablet if I forgot the password?Manual Factory ResetTurn off your Android device. ...Press and hold the "power", "volume down", and "camera" buttons simultaneously. ...Release the buttons once your Android device is powered on. ...Scroll using your "Volume up and down" button until you find the "wipe data/factory reset" option.More items...Recover Android Device in case of Forgot password/pattern unlock an ...visihow.com/Recover...in...Forgot_password/pattern_unlock_an_Android_deviceSearch for: How do I unlock my tablet if I forgot the password?
or before you do anything go to this link and have some more off a read up.
cannot remember my password to get into my tablet Google Search
2answers
How do i unlock my tablet if i forgot my password?
If you set a pass code (or pattern) that you cannot remember, please enter the wrong password (10-20 times) until you are prompted to sign in via your google account. Please note, this will only work if you have already setup your google account on the tablet. If you have not set up a Google (or Gmail) account on the tablet, you will have to perform a firmware install, which will revert the tablet back to factory settings. Support Troubleshooting Guide
3answers
How to unlock tablet that has a forgotten pattern on it
if you have a google account, you can do this option
  1. When you try different patterns and unable to unlock your phone in five attempts. Then a message pop-up and shows two buttons "next" and "try again".
  2. Now click on "next" button and you see two options for unlocking phone. One is answer the security question and the second option is to provide Google account details.
  3. Mostly people don't set a security question. But if you set it then simply answer the question and unlock your device quickly. Otherwise check the Google account option and click "next".
  4. Now provide your Google account username and password attached with your device and click on "sign in".
  5. After that you are directed to choose new pattern and now you can unlock with this pattern.
if you don't have your google account, you can do the recovery option, but you will lose all your data in there
  1. Power off your phone.
  2. Now press Volume up, power and home button at the same time and wait until your device starts.
  3. When you see logo screen release the power button and keep pressed the other two buttons.
  4. Now your screen shows android system recovery and there is a list. Use Volume up or down keys to select option from the list. And select factory reset option and then press power button to let the action begin.
  5. Now it asks you for confirmation, select "yes".
  6. After factory reset completes, it again shows you android system recovery screen. Now select reboot option and after restart it will not ask you for pattern.
How do i reset my password for my digiland 7inch dual core tablet my daughter forgot it and havein hard time resetting need easy way to fix
1) Power off the tablet. 2) Press and hold the Volume-Down and Power button simultaneously. 3) It displayed a menu in Korean/Chinese (?). 4) Scroll down (using the Volume-Down button) to the SIXTH menu choice. 5) Press the Power button to select. This will start the factory reset process. You will then be directed through the original start-up process as if you got it out of the box for the first time. If you have a Google account and if you stored your settings to Google, your previously loaded applications and saved contacts should start downloading. This is a factory reset, so everything not saved to Google will be lost.
Read more: How do i reset my digiland dl701q tablet when forgot pattern? - How to unlock a digiland tablet if you forgot your password with reset button :: Ask Me Fast at http://www.askmefast.com/How_do_i_reset_my_digiland_dl701q_tablet_when_forgot_pattern-qna8826890.html#q6437553
Hard reset
Forgot my password for my sony s tablet
Hello Let me clarify you question. When you say forgot password do you mean that you put a protective password to sign into your tablet and that is the one you forgot? If so there is no way to get back in without it unless you do a factory data reset on your device.. This will erase everything including your personal data unless you have backed it up somewhere and any apps that you have personally placed on the device as well but you can get those back as long as you use the same google account.
Before doing anything if you have a sd card in side you want to take that out or everything that you have on that card will be erased as well.
1.Press and hold the volume up button and then the power button until you see a black screen with blue lettering
2. To get to factory reset use your volume up and down button
3 Use the power button to select it.
4.Then you are going to want to do the same thing again to get to reset tablet
5.Using the volume up or down to get to Reset Tablet and then use the power button to select it.
6.You will be prompted asking you if your sure you want to reset the tablet just click on Erase Everything. Your tablet will begin the resetting process
7. When your tablet comes back up it will be up at the activation screen ie the setup process.
Hope this helps.
Hoe can I unlock my tablet
you can't. try a master reset by holding down the volume down button and holding the power button at the same time to reset it.
1. hold volume down button
2.hold power button
3. it will reset
4. fill out your info
5. wait for update
6. dont forget your password anymore
2answers
Forgot password
You'll need to do a factory reset:
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
This will reset you device to factory settings, however anything on your SD card will still remain.
At this point you will need to start fresh as if you just bought the device -- register with your email address, etc.
Top Archos Tablets & eReaders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you an Archos Tablet and eReader Expert? Answer questions, earn points and help others
