Question about Denon AVR-E400
Firmware problem. MY DENON AVR - E400 DISCONTINUED FONCIONAR. THIS ALWAYS TELLING RENICIAR UPDATE RETRY
Posted by artur on
Dennis McCollum
  • 137 Answers
You have a software glitch the processor board needs changed.
Posted on Jun 09, 2014
5 Related Answers
Kimi
Kimi
  • 277 Answers
SOURCE: Denon AVR 3801
Hi Shadow,
Do you have a problem with your receiver? If so, please let us know and we'll be happy to assist!
Posted on Nov 11, 2007
Robert Johnson
  • 395 Answers
SOURCE: Denon AVR-681 receiver
this manual is the same as the 681 the only difference is the front input and power difference. this web sight http://www.usa.denon.com/AVR1602_682_ownersmanual.pdf
Posted on Jan 13, 2008
EBC ELECTRONICS
  • 163 Answers
SOURCE: Display on Denon AVR-2307 won't work
1. Bad main transformer or
2. bad main fuse/ bad channel.
You need a repair shop.
Posted on Jan 22, 2009
petraman7
Scott Frye
  • 1175 Answers
SOURCE: Manul denon avr-1601 en castellano
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-1601&imageField.x=15&imageField.y=13
Espagnol as well ...I think
Posted on Feb 16, 2009
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: Denon AVR-2307CI HDMI won't always connect
In short, HDMI will not work. HDMI is riddled with issues, your's is just one of many! HDMI version 1.1,1.2,1.2a,&1.2b do not work 100% on any receiver. The current version is 1.3b and "so far" it works... Now the bad news; It's not just a software patch to fix the problem, it's a hardware issue as well. If your unit is still under warranty, the manufacturer will update hardware and software for you at N/C. If it's out of warranty, it's way too expensive to have done! The fix is to run your HDMI directly to your TV from source, ie. Cable,DVD, etc. then run coaxial digital or optical to your receiver for audio. The catch.. How many HDMI inputs your TV has will limit sources hooked up via HDMI. If you want further info on HDMI issues, just google "HDMI forums" and there are many different sites to answer the problems of HDMI. Hope this helps.
Posted on Aug 23, 2009
I have a Denon AVR s900 I am trying to update the firmware but it keeps failing. The update repeats and now the unit is not usable. How do I stop this?
Try pressing and holding the "tuner preset ch +" and "tune - " buttons and pressing power. The entire display should light up and blink. This should stop the firmware retry loop.
Dec 27, 2016 | Denon Audio Players & Recorders
HOW TO UPDATE THE FIRMWARE
There may not be any facility to update the firmware for this model without taking to the service center. This model does not have any device input like SD card or internet connection that would enable download of firmware upgrade. The later Denon models have this capability.
You will have to consult the local Denon service center for advise.
Mar 16, 2015 | Denon AVR-1905 Receiver
How to connect a denon avr-e400 receiver to a televion
If the DENON has an HDMI output, and your TV has an HDMI input, then use a HDMI cable. Then, use the TV's remote-control to select "source" (or "input") as 'HDMI 2' or 'HDMI 3' (assuming that you have been using 'HDMI 1' to watch TV).
Feb 08, 2015 | Denon AVR-E400 7.1 Channel 4K and 3D Pass...
I have a denon avr-400 receiver. When running a firmware update, i got the error message: Connection fail:03. Now, my receiver is not working. stuck in this endless cycle of failure messages. Help
Unfortunately a failed firmware update will result in an inoperative unit. The solution is to update the firmware directly to the chip. Not a DIY solution. A local Denon repair center will be equipped to do that for a nominal fee. Your unit is a bit older to get much help from the main company.
If you are handy you need a chip burner and the proper setup and then force the firmware onto the chip. Lot of computer guys may have that around to help.
Good luck
Jan 16, 2015 | Denon Avr-5800 Receiver Ad, 4 Pg, 2000,...
How do I get HDMI cables to sync or talk to each other. We had this problem when we hooked up an Apple TV box to a Denon AVR-E400 and our Sony HD TV. We were told to disconnect all HDMI cables unplug
Personally I would use an RCA cable and hook up the AVR.
((RCA out of TV to AVR audio in))
((cable box HDMI cable output to TV HDMI Input1))
(As far as the AppleTv I would use a separate HDMI Input2)
If your AVR has a dvd or blue ray player Hook up a
HDMI cable out to another Input HDMI3 of the TV
using separate inputs on the tv will allow your surround system to be
used on all modes(CABLE,DVD/BLUERAY,APPLETV)
Sep 27, 2014 | Denon AVR-E400
Network wont come on , says error offline
If you have done a Denon reset and you still get the same thing, the hdmi/network pcb which is on the same board as the hdmi is defective.
Jun 29, 2014 | Denon AVR-E400
Sound goes up and down while watching tv.
Ask the manufacturer:
usa.denon.com/.../ProductDetail.aspx
May 23, 2014 | Denon AVR-E400
My AVR-E400 sub woffer not working through the Denton system
AVR-E400 has an RCA subwoofer output. This is a line level signal that must be connected to an ACTIVE subwoffer (has its own power amplifier) Also the source must contain subwoffer signal (5.1, 7.1, 9.1 surround sound etc) You will not get subwoffer signal from a stereo source such as audio CD, non-dolby type TV etc. Cheers, Don.
Dec 05, 2013 | Denon Audio Players & Recorders
Denon AVR-1912 firmware upgrade failed
I'm having the same problem, Denon has taken down the firmware upgrade for yours ( and mine) AVR-1912. My receiver is also stuck in the update fail loop. Supposedly they will have it back up, but I don't know the timeframe.
Lots of others are having the problem with the firmware upgrade. Go to
http://www.avsforum.com/t/1334369/the-official-denon-avr-xx12-model-owners-thread/16380
and that should help you out, though I can't say how much. I've gone as far as resetting the microprocessor, but it keeps trying to update, and then fails...
Dec 12, 2012 | Denon AVR-1912 3D Ready A/V Receiver - 90...
Denon AVR-E400 Logo
413 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
