I have a Gardena C1060 plus solar water timer. I've just brought it out for the spring. It has been stored in a lighted place all winter, to allow the batteries to continue functioning. However, when I press the manual button the timer flickers for less then a second (showing 30 minutes of manual use) then goes back to the program mode. Has anyone got a solution for this problem - not being able to operate it manually?
SOURCE: A FRIEND GAVE ME A
Some Gardena manuals appear on following link, and additional manuals are posted as found:
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
Also Google search "Gardena C1030 .pdf" or "Gardena C-1030 .pdf"
Be sure and add .pdf to search parameter to help isolate manuals from other internet posts
Gardena for some reason does not have manuals easily available as of today's date.
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
SOURCE: I REQUIRE AN INSTRUCTION MANUAL FOR SETTING MY
C1060 instructions translated into English:
SOURCE: I Have some Gardena T120 Water timers . We put
My Gardena T120 's timer isn't functioning well
Can this be fixed
I dont even see how to get into it
SOURCE: I have a Gardena T1030D
I have a spare manual if you can email me your address...just read your email
SOURCE: manual gardena t14e
I don't have parts sheet, and am looking for parts sheets and parts sellers to help folks at fixya.
Links to Gardena and possible Gardena manuals are found on following link:
Always take photos when disassembling products.
I've been pointed to a solution which has worked for me. The problem is that sometimes the solenoid gets stuck and needs to be back-flushed.
Cause 2: Due to long periods of storage, in particular new water computers or timers may have jammed or sticky solenoid valves which do not open immediately. Occasionally this also occurs with water computers which are put back into use after the winter break. Solution: Reverse flush the water timer by following these instructions. Unscrew the unit from the water tap. Connect a hose to the water tap in its place. Connect the other end of the hose to the outlet of the water computer (the inlet of the watering computer must remain open). Turn on the water tap and actuate the manual ON / OFF switch on the watering timer 5 times for about 4 seconds each. Then replace the water computer on the water tap. The blockage should now have been cleared.
