Question about Kipor RV Generator Sinemaster IG3000
The generator shuts off after 30 minutes with an oil level alert but oil level if full
Oil filter is very clean. air filter is new. no oil leakage any where. fuel filter is new. Yet shuts off with oil level alert.
Anonymous
Your oil level sensor is bad. It needs to be replaced. If you unplug the wire leads to the sensor you may get the generator to run, but you'll have no low oil level/pressure protection. The oil level sensor is on the engine crankcase usually near the oil level dipstick. You'll likely see a small sensor with a couple of wires attached to it. To replace it, you'll need to drain your engine crankcase before removing the sensor.
Posted on Mar 07, 2016
2010 sportsman 500 ho what causes oil in my air filter
For many models, there is a tube from the engine block that ports fumes back into the air box similar to positive crankcase ventilation. The idea is these fumes get sucked back into the air stream to get burned on the return loop. If your oil level is too high or you are riding really tough, some oil can be burped into the air box. Check your oil level, replace or just clean your prefilter/filter. We use fuel in the field to clean the excess oil it when this happens and just give it time to dry....If the bike shut down as a consequence, you may need to clean the spark plug and/or use a carb/fuel injector spray to remove in line gunk.
Jul 01, 2014 | Polaris ATV
Champion 3500 watt generator shuts down after 1 min. Not low on oil!
You have a carburetor problem. Stuck float or clogged filter. Gas cannot get into the carb as fast as it is used. Letting it sit for a few minutes will allow the bowl to fill.
Aug 02, 2012 | Champion 3500/4000 Watt Portable Generator
My dewalt air compressor with honda gx160 5.5 engine starts runs for 2 secs then dies. then wont start for several pulls. after a minute it will start but then dies again. Ive changed plug, gas cleaned...
Control your OIL level in the honda engine ? take of (beware) for only a short moment your oil alert sensor control to know if the level is correct to reset the sensor and if the engine is running for a short time good connect it again on the working engine to reset. if the level was not correct. Control the fuel hose tank filter , change sparkplug control spark on color and a measure on the switch off connector for some dirth or connection lines or other problems that will connect to massa.
Feb 17, 2018 | Air Tools & Compressors
Have a coleman powermate 6250 model #pm0545007,won't start,what to look for?
Fresh Fuel
Clean carburetor if stored with fuel in the tank and wasn't shut off
Clean fuel filter
Clean air filter
Proper oil level
Clean spark plug (just replace it, it is easier and faster)
May 20, 2010 | Coleman Powermate Premium Plus 6250W...
Fuel leaking from air box after shutting down
Hi
Thats the float valve seals not shutting off, did you clean them & set the float heights?
The overflows from the carb bottoms must also be blocked for the fuel to fill up the carbs which then leaks into the air filter
Check also that the fuel tap turns off when bike is not running
Ride Safe
Bike-Doc
May 20, 2010 | 1985 kawasaki ZL 900 A1 Eliminator
I have a honda gx 160 5.5 pressure washer. It's hard to start
do a full service on it , new spark plug /air filter foam , full oil change , also chane the oil in the pump end , carefully remove the carb bowl and remove any dirt/rust/water etc
ive seen gx160 engines last 10 years no problem and those were hire machines
hope this helps if it does please vote
Nov 13, 2009 | Computers & Internet
Maintenance
OFF-ROAD VEHICLES - Initial Service: Check carburetor adjustment, engine idling speed and starter operation/adjust if necessary, Change engine oil/filter, Check clutch operation, Check wheel runout, spoke tightness and for damage, Check swingarm pivoting point for play, correct if necessary, Check steering bearings for play and steering for roughness, Check sidestand Torque all nuts, bolts and screws to spec, Clean or replace air filter, Check tires for damage, Check front and rear brake operation, fluid levels and for leakage, Check wear levels on brake pads, Check and adjust chain/sprockets, Road Test Motorcycle. EVERY 60 HOURS: Check fuel hoses for cracks or damage, Check spark plug condition. Clean, gap or replace if necessary, Check exhaust system for leakage, Check wheel bearings for looseness or damage, Check fork and shock for leakage or damage and smooth operation, Check battery terminals for looseness and corrosion. EVERY 120 HOURS: Check valve clearances, Clean spark arrester, Repack swingarm bearings, Replace fork oil, Replace brake fluid
Nov 10, 2008 | 2005 Yamaha WR 250 F
Kipor RV Generator Sinemaster IG3000 Logo
445 people viewed this question
Top Kipor Electrical Supplies Experts
Vernon Taylor
Robert Wooley
Robert Wooley
ray gallant
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
