Panasonic Lumix DMC-FZ20 Digital Camera Logo
Question about Panasonic Lumix DMC-FZ20 Digital Camera
Message says reset time turn off camera and turn on again
Error message "turn power off and on again" I did this and it did not work.
Performing a manual power reset (If your camera does not have reset button and initialize function)
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
When I turn my DSC W230 Sony Camera on the lens opens and closes several times then finally closes and I get a message to turn it off and on again, but it just keeps doing the same thing. I have tired...
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1
Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Camera is not going ON, message appears that "turn the power off and on again" but all other features are working properly, like date, time etc.
Reset your camera by pressing the reset button using a hair/paper clip. This should reset the settings back to factory
When powering up my cyber-shot N50, the lens extends and retracts several times, then a message appears, "Turn the power off and on again" I can download to laptop, took battery out, charged up and put...
The exact steps can be provided with the correct model #. The model # starts with "D". Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks,
KenSolutions
FixYa
When i turn the camera on, the lens goes in and out, and then there is a message on the camera saying, "Turn the power off and on again". I do this and I still get the same error message.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks for contacting FixYa.
Error message when turned on
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
6helpful
2answers
Turn the power off and on again message
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
1helpful
Message turn power off and on again
your lens may be jamed thats why it tells you to turn off then on its tring to cycle the lens so i would check that first! good luck!
Message "turn power off and on again"
Your camera has dirt in the lens, you need to get someone to take camera apart and clean it. This is very difficult to do if you dont have any knowledge of cameras. You could send to sony, they will repair, around $95 plus shipping. Kind of expensive. Cheaper to buy new camera. But you have nothing to loose by trying to take apart clean and lube lens.
Sony cyber camera
The Camera is displaying the Turn the power Off and On again message when the Lens in the Camera is stuck or when any internal malfunction happened.
To resolve the issue turn the power off and on several times. If the issue persists, try power resetting the Camera. To power reset the Camera, remove the battery from the Camera.
Press and hold the power button on the Camera for 30 seconds.
Remain the camera without power for 60 seconds and re-insert the battery.
Also try resetting the Camera back to factory default. Press the RESET button located at the lower right corner of the control buttons using a sharp pointed object.
Good Luck
Thanks for using FixYa
Top Panasonic Cameras Experts
Narseman
rhodesworks
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
