Parts list manual
SOURCE: Bunn VPR 04276-0003
There is a thermostat underneath the top of the machine. There are a couple of little screws that you need to undo then you will see a little dial or even a little T on top of a metal box or circuit board. I recommend that you unplug the machine before opening it up. Then just turn the thermostat down - usually counter clockwise. Turn it just a little and put the top back on the machine and let it heat up.
SOURCE: Bunn Coffee maker leaking out
that needs to go back to bunn for a replacement tank, they will likely only charge you for return shipping
SOURCE: Water supply for Bunn coffee maker
open the cover on the brewer- depending on your model, it could be the front or the back cover. look for a brew timer dial. turn this up slowly, running a brew each time to see if you now have a full pot
SOURCE: BT10B Coffee Maker: When I use Dunkin Donuts coffee in my Bunn coffee ...
Dunkin Donuts is a finer ground coffee and the water comes through so quickly that it isn't absorbed quick enough so you don't get the full flavor and it causes an overflow. If you will call Bunn Customer Service, a new flow restrictor can be sent to you to resolve this problem.
SOURCE: my bunn coffee maker is leaking water out of the
Please get the model and code date located on the bottom of the brewer. The machine has a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, it will be replaced at a discounted price. Once you have this information please call customer service.
