THE TV WONT TURN ON,WONT STAY ON/ AS IF IT WERE IN A SLEEP MODE.THE RED LITE / DOMINATES THE GREEN - ON LIGHT.CAN YOU HELP?MY EMAIL IS [email protected]
SOURCE: Insignia NS LCD32 standby light blinking off and on. No Power
I had this problem as well. Actually best buy just left my hosue to fix it. This is the second time they were here to fix it. The first time they said a part was loose. This time they had to replace a part.
SOURCE: How to remove the back from Insignia NS-32LCD?
I unscrewed all the screws in the back, detached the tv from the base, and was able to get the back off. I ordered a new power supply board and will install it to see if it fixes the problem with the tv (won't turn on, insignia light alternates between red and blue). I didn't notice any problems with "swollen" capacitors, so if the new power board fixes the problem I'll update this website.
SOURCE: INSIGNIA LCD won't turn on
replace 2 condensers in the power supply with greater voltage ones.original are 1000uf 35volt...use 1000uf 65volt...99cents each
power circuit is made to fail with typical tv industry tactics...the warranty is reflected by the life of their condensors (capacitors) average life is 2000 hours..
easy...huh
if your a smoker...you must clean the button cover as they get stuck on with your stupid tobacco residue. 75% of all LCD tv's that smokers own fail this way...
\tough huh?
TRY TO STOP SMOKING...
SOURCE: Need base for Insignia TV
It will either slide out from the front/back or to the side..Some actually bolt on from the bottom using screws/bolts.And then again some are not meant to be taken off.Make sure it is a wall mountable tv.Then try to take the stand off as directed.
SOURCE: No picture, no sound, does light the insignia sign. Why?
In about 90% of the time the power supply is defective if the TV fails to power ON.
I repair these power supplies, if you need further assistance write to [email protected]
