Question about Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television
How to open pioneer sd-582hd5
My tv is acting up, when I switch it on, nothing happens, there is green led on the front panel but nothing happens no image or sound.
read on forums, I might want to try and
(1) re-solder the PS board.
(2) check the fuses and ic's
(3) check convergence unit
How do I open this box ? From front or back ?
Anonymous
I had the same problem try the fuses that should do it if thats it but there might be a short
Posted on Dec 03, 2007
marco amezcua
  • 143 Answers
From back good luck most problems are cold solder connections and i some models you have to replace three small caps in the video circuit
Posted on Nov 15, 2007
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from www.cnet.com
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Jan 18, 2016 | LG Televison & Video
White screen
"White screen" on Samsung LED TV - Forums - CNET
CNETJun 11, 2015 - I guess I better send it to the repair shop and prepare myself for a long break ... Hello i have experienced the white screen tv as well, i got mine as part of a deal ... Samsung LCD Green Screen
Jun 11, 2015
Samsung DLP TV w/ White Dots on Screen
Jun 11, 2015
Samsung DLP white dots fix?
Apr 10, 2012
Samsung LCD TV now bright white screen
Aug 1, 2011
EASY Common BLANK SCREEN FIX FOR LCD SERVICE ...
? 4:42
https://www.youtube.com/watch?v=SARGnOExL8c
May 11, 2013 - Uploaded by Tampatec
EASY Common LCD REPAIR Blank WHITE DISTORTED VIDEO... LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test ...
Samsung TV "white screen" repair - YouTube
Dec 16, 2015 | Televison & Video
TV appears to get AC Power, but can't get anyuthing to work on it.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 13, 2015 | Televison & Video
When i switched on the tv it looks like normal. but after a few minutes the tv shotdown .and when i tried to switched on again the tv, standby power is there but when i press the channel button, the...
It sounds like you may have faulty tact switches on the front control panel that are acting intermittently. If one of the switches is defective it can cause all kinds of erratic behaviour.
Nov 29, 2009 | Sanyo DS20930 20" TV
Green led keeps flashing no power on
Please read the solution on this thread; I keep repeating myself :-(
Bad power supply
Sep 06, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Tv wont trurn on
Re-check the lamp door alignment. If the door is not installed properly, the interlock switch will open causing a no start condition. Also observe the red LED on the front panel. When you turn on the TV, a gree LED will blink on and off until the image appears. If the image fails to appear the green LED will give way to a red LED that will flash a specific number of times in between pauses. 3 blinks means the door is not installed correctly. 4 blinks means that a fan has stopped working, etc.
michtech
Feb 17, 2009 | Sony KDS-50A2000 50" HDTV
Ya...Ok
Good Day, egear00;
Did you try the DMD board? Other wise I'm still looking for solution.
big IRISH.
Aug 21, 2008 | Hitachi 60V500 60" Rear Projection...
Dell Dimenion 3000
sounds like you need a new motherboard. Try to reset the bios with the jumper (or remove the battery and unplug it) and see if that does anything, if it doesn't start looking for a new mb.
Jun 04, 2008 | Dell (E210882) Motherboard
Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television Logo
147 people viewed this question
Top Pioneer Televison & Video Experts
Marvin
Marvin
Ekse
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
