Computers & Internet Logo
Question about Cnet Computers & Internet
Cnet cnp4300 and windows 7
How can I make this print server work on windows 7
Posted by Dave Ford on
2 Related Answers
Anonymous
SOURCE: Does a Level1 WPS-9122 print server work with Windows 7?
Yes, You can purchase WPS-9122 and use on Windows 7. Though the seach utility comes with WPS-9122 may be out of date, in another word it might not be compatible with Windows 7 since WPS-9122 came out long before WIndows 7.
For your reference, most of the networking equipments are OS independent. For example, printer server, router, switch. The version or type of OS does not effect it;s usage.
LevelOne Technical Support
Posted on Feb 09, 2010
Anonymous
SOURCE: I recently loaded windows 7 and now I cannot print
Start > Devices & Printers > Add a Printer > Add a network, wireless or Bluetooth printer
> The printer I want isn't listed (unless it is!) > Add a printer using a TCP/IP address or hostname
> Device Type = Autodetect / Hostname or IP address: 192.168.XXX.XXX (The 1260's IP assigned by
your router - make it a static IP beforehand) / Port name: [the autofill IP is fine] > Additional port
information required = Standard "Network Print Server (2 ports - USB)" > Select the driver for the printer
you want to use...
Once the install is complete go to the Devices and Printers screen and click on the new printer.
Click Customize your Printer, change the name if you prefer and then on the ports tab. Mine is
set to Protocol "Raw", Port Number 9100, Community Name "public". The only other thing I may be
doing differently is that I have set the printer to auto-show the print preview before printing.
Yes, its an additional click but it seemed to have made all the difference in my case. It also
gives you the chance to correct something like printing a second page with just a header URL, etc.
I realize that time is a luxury and not everyone has a lot of it, especially for trivial tasks
like addressing antiquated equipment compatibility issues after an upgrade, but I firmly believe
if you say can't enough, you WON'T. But for those who enjoy a challenge occasionally I hope this
points you in the right direction. Good luck
Posted on May 12, 2010
Run a cnet cnp430 on windows 7
I hope you are connecting the print server to a network hub or switch and not trying to connect directly to your Win 7 machine.
There are no drivers, a print server is a network device. Connect the ethernet cable from print server to your router. connect your printer to the switch. Search the network for the printer.
Is it compatible with windows 7?
The latest firmware for this print server only support Windows Vista and below , sorry to say that as of now it will not work with Windows 7. If Dlink releases a new firmware to make this unit with Windows 7 just need to update the firmware and you can use it for Windows 7 computers.
How to work in window 7, I work in xp no problem, but window 7 not work
Is the server windows 7 compatible?Not all hardware is compatible with this OS.If not you will have to get one that is.
2helpful
2answers
I have window 7 64bit and the keyspan software installed fine but the server utility does not recognize the print server. I allowed port 3842 tcp and udp through the windows firewall but still no luck.
for key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install windows virtual pc, start it up and insert a windows xp pro install disk. for info on this google 'workaround to install windows xp mode in windows 7 home premium and home basic') Once you have windows xp mode running, install the keyspan server utility int he virtual machine and setup as usuall. then share the printer. go to windows 7 devices and printers and add a printer, chose a network printer, select the new virtual machine and select the shared printer. In order for the printer to work just start up the keyspan program from windows 7 and print....your welcome.
1helpful
2answers
I cannot find a driver or SW package for Windows 7.
Tripplite bought Keyspan and are no longer supporting it. there are no 64bit drivers.
1helpful
GMfPSU21W6 usb print server support windows 7 & Vista
When I upgraded from XP to Windows 7, Iogear tech support told me that they had no intention of offering Windows 7 support for my GMFPSU22W6, so I dumped it and bought a D-Link DPR-1260 instead.
1helpful
MY WINDOWS 7 LAPTOP WONT RECOGNISE PRINT SERVER
Please note that all old devices drivers have upto windows xp or 2003 server files becuase now only windows 7 has been launched in the market. So don't worry you can download print server drivers from the site .
If your print server is USB connected , the windows 7 will say found new hardware after that it will ask you update drivers, there you can click on have disk and locate the driver files where you have kept and clickon windows 2000 or xp from here you can select the driver and install it. Defently your print server will work.
If this answer is helpful ,pls rate it.
1helpful
Top Cnet Computers & Internet Experts
 Mike M
Mike M
NOEL
NOEL
matt
matt
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
