Marantz SR4600 Logo
A
Anonymous Posted on Apr 05, 2014
Humming noise after power outage
After a recent power outage, speakers only have a loud humming noise....peripherals seem to work (tv, etc.), display on receiver looks fine, can switch to each device, only dvd does not have humming noise. any ideas? thank you
1 Related Answer
Seamus377
  • 99 Answers
  • Posted on Sep 12, 2010
SOURCE: only one speaker works in dvd/cd mode, both work when you use AM/
could be dry solder joints on the input of the amp?
Monitiors are not turning on
Have you tried to use these on other devices, like a DVD Player, etc.? If you get a HUMMING noise with other devices then the internal amplifier is defective and you are not getting sound production to the speakers. If you have separate power AMP and the speakers hum when connected, they may have been damaged. If you have a speaker mismatch; they tend to buzz, thus too many conditions could represent the humming. Check that the Positive and Negative polarization of the speaker wires are correct.
The sound is not working on my Hitachi L42Vc04U tv
Before you assume the set has a audio problem here are some other possible causes to at least explore:
Speakers in the set (menu) are switched off.
Volume and set and or box turned way down or muted.
Internal/external speaker setting set to external
Audio works with a DVD etc connected to rear a/v jacks
Set suffered a power outage=unplug set and boxes and wait--plug both back and see if fixed or not.
Set does display on screen audio level or not--same for a box if used.
Check all audio settings in set and box carefully
If all these fail do you hear a hum or very faint audio from the speakers?
1helpful
I have a pair of JM lab Electra 905 speakers, running through a DNM amp and power amps. When powered up, the left speaker makes a very loud humming noise. This has happened recently. I haven't changed...
Hello
Switch on your amp, keep its volue down to extreme low, and listen if there is still hum through the left channel or not. If still there is hum, the left side power amplifier section inside the amp;ifier is faulty. If htere is no hum at this state, hum enters thorugh the audio input terminal, and the input wires must be checked for open sheild connection. OK.
1helpful
Making loud humming noise only.but if you plug
If I understand this correctly: with NO input or cable attached it hums; with an RCA cable attached it works. (What does 'some' mean in this regard?)
You say that connecting the RCA cable improves its sound. That tells me you're supplying a ground through the RCA cable for stray voltage in the sub.
It seems there may be a basic power issue if it hums with no input. Sometimes a given power source in a home may be wired differently than others or may insufficient grounding, which can result in hum. Try reversing the sub's power plug or move it somewhere else.
Since the sub contains its own electronics it is also susceptible to strong external magnetic fields. Keep it and any signal cables leading to it some distance away from other electrical devices like TV's.
Speaker makes a rather loud humming noise.
You can go buy a audioquest SUB-X subwoofer cable with a additional ground wire on it an connect the ground cable to the ground slot of the receiver an the other end to a screw on the sub or into one of the high output terminals on the woofer if it has them an this will take that humming sound right away but the cable is around $90
Buzzing/humming noise that increases as you raise volume. So loud that you can not even watch tv
Hello snow1525,
You may have a torn speaker element. This is usually the cause of buzzing noise in the sound, also you may have a bad capacitor in your audio section. This is what I would suggest doing as a test open the front bottom panel of your TV and visually inspect the speakers for signs of ripping and or tearing in the speaker element. If the element or elements are torn it may be possible to repair it with rubber cement or rubber paste just coat the tear with the rubber cement to hole the torn edges together and allow it to dry for two days before testing the sound. If the speaker elements are not ripped then the problem may be a bad capacitor either in the audio section (power supply) or in the filter block (usually attached to the speakers to separate bass and treble signal to the speakers.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
1helpful
I have a Polaroid 37" (flm3732) that makes a loud whineing noise that also sounds like an electrical arc for the first 15 min after turning on. The time period seems to be getting longer as the days go by....
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected] if you require further assistance.
3answers
Loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
2helpful
Loud humming noise from new hdtv
hello, the speakers are fualty or have a shorted connection if they came with the tv contac your seller and arrange for a replacement imediately dont wait. since they are giving you feedback dont use them they may cuase other fualts in your tv, any component thats cuases hum or noise when pluged into the tv should not be used at all.
one important thing is to have a grounded plug this also may cuase fualts down the line,
if posible get a power line conditioner or ups (uniteruptable power supply)
flat panels are very over protective you dont want the tv to start blinking. since flat panels have built in protection circuts any slight short or fualt may cuase the wide screen to go into circut shutdown mode and this will cost you more if the speakers create a short in your audio circut it may damage your widescreen internal boards and cuase a system shutdown circut (red light flashing no picture)
contac your sellers site let them know your speaker are cuasing a loud hum
and that you will need the speakers replaced these are definitely fualty
if you dont have any coverage or you got the set as is then dont take any chances use other speakers.
if you are electronically inclined you can open these up and find out whats wrong with them internaly it may be a loose connection, since opening up the equipment may void your warantee contac the store first see what they say..
good luck happy holidays
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
xxxxxx xxx
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
