SOURCE: Sensors not working correctly ... jamming
Try blowing some canned air down into the feed slot to clean the sensors.
SOURCE: does not shred red light on
Try soaking the cutter blades with hot soapy water overnight thru the feed slot
SOURCE: The number on top of my activa shredder is DQ83M,
shredded afew times aqnd thanone time nopower4 wont shred ready lite comes on
SOURCE: red overload light is on
Try pouring some shredder oil into the throat where you normally insert the paper and run the machine in reverse.Put machine back into ready condition.
Put a piece of paper in the throat just enough so the machine should run but not all the way in so that the cutting mechanism catches the paper...all you want to do is make the machine run forwards but not actually be feeding in any paper.
If it wont even run in the forward direction you may have a pcb prob...give Royal a call at 1-800-524-0799 for parts assistance.
