Question about Sony KP-46WT510 46" Rear Projection HDTV
Blurry on one side of screen. Green and purple shadows
The TV turns on and has a color picture but now the right side of the  screen has green and purple shadows on words and people on the screen.  It makes it very blurry, but just on the right hand side of the screen.
Posted by jmat00 on
  • 1 more comment
  • jmat00 Nov 02, 2007
    If you go to the convergence screen, every + is out of alignment on the right hand side of the screen but you cannot move them to realign.
  • Anonymous Dec 29, 2007
    I have a Sony 53 inch Rear Projection Hd Ready Tv. Mo# KP-53HS10
    SER # 9723345.
    I recently got an HD Receiver from Direct TV and the 5LNB Dish. Using the Y/G Pr and Pb plugs to connct it to the Tv. When I tune to an HD channel and the Receiver says its broadcast in 1080I the right side of the Tv is blurry and very unclear. Only with the 1080I broadcasts. The 480I and 480P are fine.
    Any help would be greatly appreciated.
  • lettering1 Mar 23, 2008
    how do you program the remote to get into the convergence screen.
Anonymous
Right side of 65" jvc televison is blury while left side is clear
Posted on Jul 12, 2009
Vista Electronics
    Genius:
  • 1,694 Answers
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Posted on Dec 04, 2007
The left half of the picture has gotten blurry, with pink, green outlining what seems like 3 different pictures of the same thing. The left half works fine and the HD of direct TV is good on that side. I...
The tv have a problems known as a tv convergence pictures problems,it is dead.Tv set have any colors lines like R,G,B mis alingnments,have colors shadows pictures or a 3D pictures look alike?Yes,than the tv set convergence board it is dead to causes all these pictures problems.The tv set convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv set convergence board to solved the tv set covergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 18, 2011 | Sony KP-65WS510 65" Rear Projection...
My tv on the right of the screen is blurry,with green around the images.
Ur tv have a problems known as a convergence picture problems,it is dead.The tv have R,G,B colors lines mis alignments,tv have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead tv convergence board.The tv convergence board must require changes 2 STK convergence ICS and some or all of it resistors too.After the tv convergence board is fixed,the tv convergence picture problems will be solved.The tv shop,will cost u like $300-350 for parts and labors.
Apr 26, 2011 | Hitachi 53UDX10B 53" Rear Projection...
I just turned on my tv and there are shadows around everything on the screen. Purple ones on the left of the object and green on the right. I was just watching it last night and now it's doing this. ...
Very common problems with the DLP projection tvs.The tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignments,have colors pictures shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Blurry picture and purple and green color on top and bottom screen, cable channel indicatoe showing doubled
Tv have a problems known as a convergence problems,it dead.The tv convergence board,require 2 STK convergence ICS and some or all it resistors to be replaced to solved the convergence problems.The shop will,cost u $300-350 for parts and labors.
Aug 08, 2010 | Toshiba 50H82 50" Rear Projection...
LEFT SIDE OF PICTURE IS BLURRY AND COLORS DISTORTED
Does that set have whats called a color wheel, if so that maybe you problem, and replacement is how you fix it.
Apr 30, 2010 | Toshiba TP43H95 43" Rear Projection...
Green and purple shadows in the left upper corner
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
My sony 24in flatscreen has green color on right
dont power your tv near sound box or machines with magnet,
switch off tv, get a magnet and pass it all round your screen, it will clear with no time
Mar 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
Green shadows all over the screen
You didn't say how old the set was and how much it's used, but the shadows you're describing sound like a bad green picture tube.
Hope that helps...
Geno
Apr 25, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
1,813 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
