Question about Fortec Star Lifetime ULTRA
Fortec fs 4200error code 8 on switch on - Fortec Star Lifetime ULTRA
Kyocera fs4100dn with error code f245
The proviso of whether it's B or 8 holds.
http://www.copytechnet.com/forums/kyocera/82182-what-error-code-f24b.html
Feb 10, 2015 | Kyocera FS-4100DN A4 Mono Laser Printer...
Scramble
how to unlock channel on fortec star fs4200
Jun 19, 2009 | Fortec Star Lifetime ULTRA
Hi, I need to watch scrammbled channel with my Digital Receiver
hi my name is mark, if you are on a C band dish, analog, digital or j-peg.some programmers that didnt scramble have started to and alot of them have updated to digital. you can try http://www.skyvision.com/ hope this helps. thanks for your question.
Mar 17, 2009 | Fortec Star Lifetime ULTRA
Fortec Star HD Passion + Receiver, reset problems + 7 day guide
check is the .dnl file ending missing if so just renane the file p2_av108_20081114.dnl
Dec 09, 2008 | Fortec Star Lifetime ULTRA
Fortec Innovative
Hi, you need to connect to the router using an ethernet cable, and not in wireless mode.
If you are using wireless, that can be the cause of the problem.
Disable all firewalls on the computer you are using. Also firewalls can block the network.
If it still does not work it Depends on Fortec, in some way they are cutting you out from the network. Ensure that you are entitled to download codes, it looks like their server is cutting out your IP right after you connect to the network.
First ensure that you are entitled to download codes if you are not this can be normal, after a while they can spot and block an IP. Give them a call to ensure it is not that your IP had been blocked.
If your account is fine, try updating receiver firmware.
Here is the download page
Sep 09, 2008 | Fortec Star Lifetime ULTRA
Fortec ultra
Hi! Did you check the rear power switch, the front micro switch, the continuty of the power cord, did you already check that you have the output voltages in the P1 connector. In the CPU STi5518 on pins (4,47,81,107,136,159,184) you have to get 3.3V, on pins (14,37,64,94,119,149,171,198) you have to get 2.5V. I hope this can be usefull for all of you.
Roadcyclist33
Jan 08, 2008 | Fortec Star Lifetime ULTRA
Fortec star ultra
you have to find the new key codes
Dec 27, 2007 | Fortec Star Lifetime ULTRA
My reciever
go to www.dss/keys.com
Fortec machine has not power
fortec machine has not powwer
Dec 09, 2007 | Fortec Star Lifetime ULTRA
Televison & Video Logo
50 people viewed this question
Top Fortec Star Televison & Video Experts
Marvin
Marvin
Are you a Fortec Star Televison and Video Expert? Answer questions, earn points and help others
