Question about Mitsubishi VS-50605 50" Rear Projection Television
55IN TV. THERE IS A LINE THAT GOES ACROSS MY SCREEN AND WORKS ITS WAY UP THE SCREEN AND THEN WORKS ITS WAY BACK DOWN AND THEN THE TV TURNS OFF BY ITSELF. WUT COULD B THE PROBLEM. ALSO THE PICTURE JUMPS. CAN U HELP ME
Posted by BXMIKE on
Sonny Berry
  • Mitsubishi Master
  • 8,617 Answers
1. VERTICAL ROLLING, VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE, ALSO MAY HAVE HORIZONTAL PULLING OR TEARING. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01
Posted on Jan 26, 2008
I have 4 vertical purple lines and going across my and they are increasing in size. I have a RCA 55in LCD Tv
Back light problem. Check and replace the damaged components at its back light inverter circuit board.
Feb 03, 2017 | RCA Televison & Video
Have samsung un55c9000zfxa led tv with horizontal lines across screen can it be fixed?
It's either the control board or the display itself.
You'll have to find a TV repair company. They won't be able to tell you for sure until they test it, and they may charge you to test it. The control board should be a cost effective fix, the display won't be.
Unless you're trained in Electronics, don't open up the unit and try to fix it yourself, there are hazardous voltages even when the TV is unplugged!
Jul 18, 2016 | Samsung Electronics UN55C9000 - 55in 9...
Just got this tv from friend. has no remote. screen is black. sound is good. when you push menu button, white line goes across horizontally the screen.
The horizontal line indicates the vertical deflection circuit is not working. Either the set is stuck in service mode for adjusting color (turns off vertical), or the deflection circuit has failed.
Some RCA TV sets have a "Service" switch in the back, down near the bottom of the set. Most of the newer sets use a combination of remote control and front panel buttons to get into service mode, and that can be turned off by unplugging the set and plugging it back in. Try looking for the mechanically operated service switch in the back first.
Jan 05, 2011 | RCA F25442 25" TV
I have a toshiba tv 27 with a line across the middle of the scree
Definitely not. You have the symptom called 'field collapse' . What happens is a beam of excited electrons is traced across the screen and when it reaches the end the beam flys back and traces the next line down. Because you have a line across then the beam is scanning across but the field circuit isnt making the beam move down as it traces across a new line. The fault lies either in your field deflection driver chip or...the power supplying it has disappeared at around 27 volts..or the booster or voltage doubler circuit connected to the chip has goe faulty.. Another fault could be the yoke connection b roken but hardly likely unless youve dropped the tv at some point :)
Aug 03, 2009 | Toshiba Televison & Video
Come on then line horizal across screen then turs off
Horizontal line (up and down) is know as horizontal collapse. This is usually located around highvoltage section of the circuit. Because this circuit depends on certian frequencies and voltage protection circuitry will shut the set down. This will need a trained tv technician to fix this and can be expensive depending on the parts needed.
Mar 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Power
Sounds to me like its your green tube. Kind of expensive replacement, but easy.
Jul 24, 2008 | Sony KP-51HW40 51" Rear Projection...
SONY KP-46WT520
does the led blink when it shuts down if so how many times does it blink? And the green line is that running up and down the screen or across the screen?
Apr 26, 2008 | Televison & Video
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Mitsubishi VS-50605 50" Rear Projection Television Logo
100 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
