Question about Pride Mobility Products Health & Beauty
Where is the freewheel latch on a karelma quattro mobility scooter
1 Related Answer
dj_relly999
dj_relly999
  • 4070 Answers
SOURCE: i have a traveller 4 mobility scooter that sudenly
Hi! Looks pretty much a control switch failure. The circuit wire may be grounded or on the circuit board itself. You will need to have it checked by an electrician for this requires an on hand fixing. Hope this helps and have a good one!
Posted on Sep 17, 2010
I have a elite mobility scooter why does it stop on me my battery are fully charged the lights go on but won't move
Hi check freewheel lever at the rear of scooter if U an push the scooter it's in freewheel :::::: push the lever lever the other way to lock it in gear .. Cheers
Nov 25, 2016 | Elite Health & Beauty
Why doesn't it move or do anything?
Mobility Scooters have a freewheel lever that allows you to push the scooter by hand instead of under power. the Freewheel lever must be in drive for the scooter to be driven under power. it is located under the seat or back right side of the scooter.
note: There are a couple scooters out there that have electrically operated freewheel feature, those are rare.
also see my app. Scooter Doctor App
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Nov 18, 2015 | Health & Beauty
Why constant beep?
It seems that something isnt properly seated. Dismantle it and put it together (mantle it?!) very positively this time, make sure the freewheel latch is fully home.
May 03, 2014 | Pride Go Go Elite Traveller Plus HD 4...
Beep code 5 keeps going off, the manual freewheel lever is in the drive position. Can I repair it?
Hi remove the key for a short while make sure freewheel lever is in drive & replace key & try it out. If this doesn't help take key out put freewheel lever In freewheel then put it in drive put key back & try again good luck
Apr 13, 2014 | Pride Mobility Products Go-Go Elite...
The red light flashes 5 times scooter will not move
I would look at the freewheel lever. Disengage and then engage the freewheel and see if this corrects the problem. If not, you may have a bad freewheel switch.
Apr 10, 2014 | Drive Medical Phoenix 3 Wheel Compact...
I have a go go elite traveller plus , the battery pack will not lift off my scooter it seems to be stuck , i need to replace the batteries
The manual for this scooter is at http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
The closest info I can find is page 14. MOVING AND TRANSPORTING YOUR Easy Travel Elite
6.1. Moving Your Easy Travel Elite in Freewheel Mode when unfolded:
The Freewheel switch (Fig. 1/17) is used for releasing the brake and moving the Easy Travel Elite without operating the motor. Before activating, make sure your Easy Travel Elite is switched on. Turn Freewheel switch to the "freewheel" position and push or pull the Easy Travel Elite manually.
NOTE: The Freewheel mode can only be activated after the battery is in place and the power switch (Fig.9/1) is turned on. Doing otherwise will cause a fault situation indicated by rapid flashing of the Indicator light (Fig. 9/4). See section 4.2.
WARNING: The Freewheel switch should never be engaged on a slope.
CAUTION: The seat back must remain in the upright position.
They seem to assume removal is obvious, I would check any connections from battery to scooter are pulled out and that freewheel mode is not engaged.
Oct 07, 2013 | Pride Mobility Products Go-Go Elite...
I HAVE A PRIDE 3 WHEEL GOGO SCOOTER. THE BATTERIES WENT DEAD. I REPLACED THEM AND CHARGED THEM UP. NOW I GET A 5 BEEP CODE WHEN I TRY TO START. IS THERE A LIST OF WHAT EACH CODE IS? THANKS FOR YOUR...
Hi Fred,
Good job on replacing the batteries!
With the go go scooter, a beep code of 5 indicates a solenoid brake trip. This means that the brake manual/freewheel lever may be in the freewheel position. This means that you can push the scooter. Remove the key and push the freewheel lever to the drive position. Restart the scooter and the code should be cleared and the scooter will run. Hope this helps.
Jan 19, 2011 | Pride Mobility Products Go Go Ultra X 3...
Have a Bolwell mobility scooter with the problem that it will not go. Battery indicator indicates fully charged but left indicator bar on battery display is flashing with a clicking sound near rear wheel...
Hi u mention the brake is off do u mean it's in freewheel if u can push the scooter it's in freewheel .push the lever into drive : when lever is in freewheel the scooter will not move..type in Google search ( bolwell mobility scooter manual ) .cheers
Jul 05, 2017 | Health & Beauty
Rover three wheel mobility scooter full charge horn working but just wont move
First of all,
Make sure the freewheel lever is unengaged (up or down ?) , this can be tested by pushing the scooter forward , you should hear gearbox clunk,(Freewheel not engaged) Not all scooters sound a alarm when freewheel is engaged.
is the power indicator working okay,
Does the Wig Wam move freely, the thumb throttle part,
Check under the seat to make sure you have not blown or tripped the fuse, if it's a switch simply pressing the button will sort it, if not check the two prong fuse ,
you may also have some reset buttons on the stem so look out for them.
Now let me what you tried
Regards
GeWiz.
Jul 20, 2009 | Electric Strider Maxi 4 Wheel Mobility...
The scooter rar wheels locked up nothing moves
hi, if the freewheel lever is jammed which is located on the drive motor, take the rear cover off and make sure the lever is not bent,
you will see how the freewheel lever is mounted under normally a rubber cover on the side of the electric motor ,
Let me know
May 16, 2009 | Pride Mobility Victory 3 Wheel Electric...
Health & Beauty Logo
123 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
