Not knowing which model you have, here are the instructions for my model. Perhaps yours is the same.
"The Automatic Shutoff
Time can be programmed anywhere from immediate shutoff after completion of the brew cycle up to four hours. When the coffeemaker shuts itself off, two tones will sound. Two hours is the default time. The 0:00 setting shuts the unit off immediately after brewing is complete.
To check the current setting, press and hold the On/Off button and the Automatic Shutoff Time will be displayed.
To change the preset time, press and hold the On/Off button until the red power light and LCD display begin to flash. This signals that you have entered the Set Automatic Shutoff mode.
Press the Hours and Min buttons to scroll forward through the digits until desired time appears. The first setting which appears is preset at 2:00. When it's at 4:00, the next press key of Hour will roll back to 0:00, since four hours is the maximum Automatic Shutoff setting. Pressing and holding either button will allow you to scroll continuously, slowly at first, and then to accelerate to the rate of about three digits per second. As the desired time setting approaches, release the button and then press repeatedly to advance one digit at a time. The Automatic Shutoff Time (ASO) may be 8 9 programmed either before or during coffee brewing. You may also re-program the ASO time when brewing has been completed. If you do so, the Grind & Brewâ„¢ will automatically account for any time that has already elapsed after brewing. For example, if you set the ASO for 40 minutes and 25 minutes have already elapsed, the Grind & Brewâ„¢ will shut off automatically after 15 minutes (40 minutes minus the 25 elapsed equals 15 minutes)."
Mine doesn't have a specific clean cycle, but to decalcify the unit, add 1/2 vinegar to 2/3 water in a full cafree and run it through. If it's really calcified, turn off about 1/2 way through and let it set for an hour. Then turn it on and finish, Remember to run a pot of clean water through the wash out the vinegar taste.
It might be that you need to replace the battery because to my knowledge some cars are equipped with an automatic fuel shutoff but not an automatic shutoff.My advice to you would be to take your battery to be tested by autozone or advanced auto parts or a store like these. They can test your battery for free.
I think that standards require an auto-shutoff on electric pots to keep the component from softening down. You could override the shutoff by either taping over the switch or utilizing an elastic band. You can check deep details on electric kettle review sites.
You have to use the "Auto-Off" feature, which is located on the same button as on/off:
The automatic shutoff time (ASO) can be
programmed to shut off immediately after
brewing (0:00) or up to 4 hours later. The
default shutoff time is 2 hours.
Press and hold the On/Off button to display
current shutoff time. To change the preset
Set automatic shutoff mode. Set the time
you want coffee to begin brewing by
following the instructions in “Entering Time
Set Mode.”
tones will sound.
NOTE: Automatic shutoff may be
brewing. If you program the auto shutoff
time after brewing is completed the unit
will automatically account for elapsed time.
For example, if you set the auto shutoff for
elapsed, the unit will shut off automatically
In order:
1 and 2) Clean the coffeemaker by puring in 1/3 caraffe vinegar, and 2/3 caraffe water. Either use the self-clean light or brew it as if it were regular coffee - just press the on button and then press the self-clean button, and it will begin.
3)
The Automatic Shutoff Time can be programmed
two tones will sound. Four hours is the default
after brewing is complete. To check the
current setting, press the “On/Off” button and
“On/Off” button until the red “power” light
begins to flash. This signals that you have
entered the “Set Automatic Shutoff” mode.
Press the “Hours” and “Minutes” buttons
appears is preset at “4:00” and the next
display will be “0:00”, since four hours is the
do so, the Automatic Grind & Brew™ will automatically
already elapsed, the Grind & Brew™ will shut
Setting Auto Off (units with timer only)
On models with a glass carafe, the auto off can be set to shut the coffee machine off from 1 - 5
hours after the brew cycle is complete. The factory setting is 2 hours. On models with a thermal
carafe, the coffee machine shuts off after 20 minutes.
Note : On models without a timer the coffee machine must be turned off manually. It
will not automatically shut off.
• Press the prog button (o), immediately followed by the h/min button (n).
• The display will show the time setting.
• Press the h/min button in steps to set the auto off time.
• Press the prog button to confirm the setting.
When the cycle is finished, the coffeemaker will beep 5 times, indicating that the coffee is ready. The unit will turn off automatically.
The insulated carafe keeps the coffee warm for four hours. The aroma of the coffee is preserved thanks to the hermatic cover. It is not necessary to remove the cover to pour coffee.
