Question about Champion 3500/4000 Watt Portable Generator
Engine surges under load - Champion 3500/4000 Watt Portable Generator
Posted by cowboytru346 on
I have a 1997 Hyundai Excel and its surging at about 3000 rpm and under load like climing hills what would cause this. Tia
Engine is surging or the transmission slipping? My guess is the transmission is slipping, letting the engine rev up to 3000. Does it feel like it quits pulling?
Oct 09, 2016 | Hyundai Cars & Trucks
I have a 2006 Impala the engine is surging at idle and when I driving
Check the vacuum hoses for a leak.
2006 Chevy Impala LS 3.5L Surge Under Load - YouTube
? 3:09
www.youtube.com/watch?v=sD-swFhMORM
Jan 22, 2013 - Uploaded by Gary Castle, Jr
Surge while driving. ... 2006 Chevy Impala LS 3.5L Surge Under Load ... How To Fix Or Prevent Stalling, Surging Or Rough Idle, Cleaning ...
Oct 02, 2015 | Cars & Trucks
2009 Chevrolet impala ltz 3900 flex surge under
Fuel filter, air filter, check for vacuum leaks.
Assuming the engine light is NOT turned on, if it is on, it needs to be diagnosed.
Oct 28, 2013 | Chevrolet Vehicle Parts & Accessories
2006 turbo diesel landcruiser trayback surges when engine is under load
possible air still in the pump so bleed at the pump
Feb 03, 2018 | Cars & Trucks
Engine surges
sounds like a carb problem if new bring it back to the store
May 05, 2012 | Husqvarna DRT900 960930011 17 Rear Tine...
S80 engine surge at idle
You could have a bad or contaminated Mass Air Flow (MAF) sensor. You can get a used one online for less then 100. You can also purchase a can of MAF sensor cleaner at a local auto supplies store and clean it. It located right at the air filter housing.
Aug 03, 2009 | 2000 Volvo S80
Engine surges under load at 3800 rpm
yes it could be. have fuel pump pressure tested, fuel pump pressure should be. (key on engine off) 1999 to 2000--with egr--41 to 47 psi without egr--52 to 58 psi,
May 30, 2009 | 1999 Pontiac Grand Am GT
Engine on riding lawn mower surging
Dirty air cleaner.
Clogged fuel filter.
Replace or clean both...
May 29, 2009 | Garden
Engine surges under load and not under load
Surging is often caused by a bad sensor in the air/fuel supply - MAP, IAC or TPS. Check for trouble codes (DTCs) using a good code reader.
Feb 09, 2018 | 1997 Pontiac Grand Am
Champion 3500/4000 Watt Portable Generator Logo
62 people viewed this question
Top Champion Televison & Video Experts
Lee Hodgson
Lee Hodgson
Harrie
Are you a Champion Televison and Video Expert? Answer questions, earn points and help others
