HP Officejet Pro 8600 Logo
s
sharon awosika Posted on Apr 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will not print. it says printer is offline
Try to print and it say's "offline" how do i fix this? i have windows 8
Bertus
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • HP Expert 177 Answers
  • Posted on Apr 11, 2014
Bertus
HP Expert
Level 2:
New Friend:
Cheetah:
Answers
177
Questions
Helped
23451
Points
289
Have you tested the Cable ( maybe test with a replacement)
under your devices and printers is the checkbox on use offline, printer - see whats printing - printer - uncheck use offline
How do I fix Ricoh printer offline windows 10 Problem?
How can I fix Printer Offline errors in Windows 10?
  1. Change printer settings.
  2. Restart the Print Spooler service.
  3. Change printer properties.
  4. Reinstall your printer drivers.
  5. Install the latest updates.
  6. Add a second printer device.
  7. Check if you're using a VPN connection.
https://windowsreport.com/windows-8-printer-offline/
2answers
Hi all MY Printer Offline In Windows 10
Brother Printer Offline Fix Windows 10 usually relates to a printhead problem and an error message shown will flash on the Screen. lights will keep on flashing as a sign of this Offline windows 10.
Method to Brother Printer Offline Fix Windows 10:-
1. Click on the Start button on your computer, and then click on the Devices and Printers option.
2. Now right-click your Brother printer icon and click on the See What's Printing option on your screen.
3. Check Full blog for the step by step solution.
Causes of Brother Printer Offline Fix Windows 10:-
Caused by some foreign trash inside the rollers of a printer or due to paper jam in Printer and many more PC causes. If the problem continues, check this blog or call Brother Printer support services or a Printer Support to stop more printer damage. The Guide is in this blog- Brother Printer Offline Fix Windows 10
If Brother Printer Offline Fix Windows 10 is not resolved, this might mean there's waste within the printer's inside. Call the customer services our check this Blog for a full solution.
4answers
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    •Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
11helpful
6answers
Epson printer offline
In this section, we provide some practical ways to resolve the Epson Printer Offline Issue. Simply follow the mentioned teachings carefully and fix this error on your own.
If your Epson printer is displaying an offline message, it means that there is some connectivity problem between the Epson printer and PC. ... Incorrect printer settings where your printer is not set as "Default Printer" may make your printer go offline. An outdated printer driver may stop your printer from functioning.
In the same way, How do I put my Epson printer back online?
Verify The Printer Connection
Update Epson Printer Driver
Check Printing Status
Restart The Print Spooler Service
Add A Second Printer
Hopefully, now you can surely Resolve this issue. I Hope, this content is valuable for you to solve the Epson printer says offline windows 10.
Epson Printer Not Connecting to WiFi
Epson Printer is Not Responding
10helpful
My canon printer says it's offline. how do i fix this?
Go to Start/Control Panel/Printers and faxes. Right click on the Canon icon and click on Offline turn toggle it back to Online. Please rate this answer.
Cheers
Bob
2answers
Printer offline
Canon, Brother, and Epson's Printer solutions are mostly the same check this answer.
The Brother Printer offline Windows 10 error normally shows up because of various mechanical issues. There can be difficulties with attachment, print queue, or something else. The printer may be facing some other error. Commonly, the Brother printer will stop printing when Brother printer offline error occurs.
10 steps that Fix Brother Printer Offline Windows 10:-
1. Make Sure The Printer Is Properly Connected.
2. Verify Printer Is Not In Sleep.
3. Check Brother Printer For Any General Errors On Computer.
4. Check Printer Status Offline Or Paused.
5. Check For Copy Of Printer In Devices And Printers.
6.Long Print Queues On Computer.
7. Make The Brother Printer Default.
8. Check SNMP Status.
9. Update Brother Printer Drivers.
10. Update Windows 10 OS.
FULL SOLUTION- Brother Printer Offline Windows 10
If you are not a Technical guy you can take help with us. by just call in Toll-Free Number that is given on Mentioned Blog.
4helpful
Printer won't print says it's offline
hi friend
this is very common problem for f300 series PSC
just delete the printer from printers and faxes and reboot the machine it will install printer again
there is funny thing abt this series it is saying offline when powered on and connected but when you disconnect iit will say "offline-use printer offline"
please try my solution and rate it
thanks
k24674
Grand Canyon Tech
Grand Canyon Tech
