SOURCE: alpine cde-9843 . i hand it in and working for 3 days then no sound.
Try a CD lens cleaner[A disk with a little brush and a bottle of fluid. But be prepared for a new player - once the lasers goes its trash can time.
SOURCE: Installing Alpine CDE-9852 CD Reciever In A Ford Mercury Sable LS
well most commen tool is a phillips head screw driver (+) to remove components to get the old deck out you'll need a dash kit to mount the new radio in 15 buck from canadian tire or audio shop...
the easyest way to wire this up would be getting a harness to plug into the factory harness too get the color code and then u just make the connections red to red yellow to yellow makes it real simple that way... the other way is to get the hanes manual for your vehicle then find out what color each wire is then yu have to cut the factory harness wire up from the book takes alot longer but can be done its worth the 12-20 dollars to get the job done if you need more help ask
SOURCE: Alpine CDE 7853 removal
remove the face and then the trim ring for face you should see 2 little pins on either side of the radio slide them up and it should slide right out
SOURCE: For the Clarion DXZ945MP CD Player for car audio,
3amp yellow battery for deck
15 amp yellow is another battery wire
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
red accessory
hope this helps
pls rate cause people arnt rating
HU harness color code pretty much universal.
red=ignition
yellow=battery +
black=ground
blue/white=remote turn on
blue=power antenna
pink/black=audio interupt in (not sure if you have one)
speaker wires
gray=right front
violet=right rear
green=left rear
white=right rear
speaker wire with black stripes is negative.
