SOURCE: Hinges and top cracked on my Dell Inspiron 1525
unlikely that its still under warranty, but you can check the warranty status at support.dell.com
you may also find parts lists on their website. The plastic bezels on laptops aren't very hard to replace.
Don't Forget to rate the advice!!
http://www.aa1consulting.com
SOURCE: dell inspiron 1545 start up problem
try press F12 when you see the DELL Logo, if it still goes to BIOS you need to replace keyboard
SOURCE: Dell inspiron 1545 laptop and the same webcam problem.
open your my computer, click on "c" the system will tell you the information is hidden, click on the link and open up the operating system and look in the drivers or there in C and se if you can find you web cam driver, when you find it you might have to force the opening of the driver to install, and once you do that plug your web cam in and see if the system see's it and installs the drivers for the cam, if you installed the driver origanally witht he web cam installed you will have to remove the web cam and unistall the driver and re install it and then plug the web cam back in, and that should help correct the problem.
SOURCE: dell inspiron 1545 power on administrator password pro
You can get a Password Reset disc download and burn to CD. Copy/paste the address below, into your address bar of your browser.
http://pogostick.net/~pnh/ntpasswd/cd080802.zip
Download this file and burn it to CD. Put into drive and turn on PC, and boot from the CD. Follow instructions, choose the correct USER. & BLANK the password. make sure you say OK to write the data, and reboot. The logon password will now be reset blank.
SOURCE: blank screen on my Dell Inspiron 1545
if your getting your dell logo it means your disply is working fine
may be u r windows is not working properly just try to up-date your windows with any windows disk
