Washer stopped spinning after lights flashed in sequence. Cleaned out sump - found some plastic in it and lights stopped flashing but now drum not turning. Motor does seem to be trying but no joy
SOURCE: My hotpoint aquarius wd440 washing machine - flashing lights ?
I have a fairly new Hotpoint Aquarius machine (out of guarantee).
When it is switched on, all of the red lights flash and it will not operate.
Can you help please ??
SOURCE: There is a series of
hi there,
i had similar problem . there is a blockage in the fllter , probably a small sock. the filter is at bottom right hand at front of machine .
turn anticlockwise to open.
regards
big eck
SOURCE: hotpoint washer dryer lights flashing
Check first the thermal fuse.
Test heating element to ensure is not grounded, and staying always on. Test the fan and ventilation system.
If you find no fault in there , then test the timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
SOURCE: my hotpoint aquarius wd440 has flashing lights
First of all try cleaning the filter inside the back as described by others if this does not work there is a filter in the top. how you clean this is quite easy. all you do is remove the top of the machine by undoing the 2 screws at the back then pull top top backwards when you have removed the top you well see a large metal casing on the left if you are looking from the the back of the machine the filter is in there to remove the casing you pull the small pipe off then undo 5 star headed screws then gently pull the casing off noteing that there is a large pipe at the front when you have remover the casing you will see the filter (the small pipe you removed at the start fits on this filter) clean the filter then put it all back together.
SOURCE: hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
