I don't have sound in the home theater
SOURCE: Unlock Philips HTS-3565
Hi
TURN ON THE PLAYER
PRESS OPEN/CLOSE TO OPEN THE TRAY
WITH THE TRAY OPEN, PRESS STOP-7-3-4-4-6-6
YOUR REGION AREA WILL BE DISPLAYED.
PRESS "0" TO UNLOCK ALL
PRESS "OK"
SOURCE: cracking popping type sound coming from front and center speaker
if u are trying to connect the audio of ur tv as input to flow out from the home theater; this is a common thing; u need to replace the audio cable that connects the tv to 3565 with a good quality cable
SOURCE: How do i connect a xbox 360 to a philips hts 3555 and hd tv?
Connect audio out cables (L and R) from HDTV to far left audio input at back of hts 3555. Then connect HDMI output from XBOX360 to HDMI input slot on TV. Setup XBOX 360 for audio through HDMI turn TV off and then on and all should be good. It worked for me.
SOURCE: IM tryin to hook up
What you really need is the audio from the cable box to come in directly to the MRD. Ponder this: why do you need the Cable Box audio to richochet off the TV first? Does it ADD anything?
The BEST audio from any source should go to the MRD first. The best Video should go to the TV first.
