Question about Whirlpool WTW6400SW Cabrio Washer
Whirlpool cabrio washing machine doesn't spin
Whirlpool Cabrio washer just stopped spinning. on the load before it stopped spinning, it did make a lot more noise than normal. on the next load, no longer spinning. any suggestions?
Posted by Reed Parker on
qvo523
    New Friend:
  • 122 Answers
Try to turn the drum by hand, if it hard to turn, there may be something stuck underneath spin basket. If it does turn freely but makes a loud growling sound, you probably have a bad bearing. You should notice black oil and water mixture at bottom of washer, on the rotor. It will usually throw a f51 error code. This unit has service bulletin on this problem.
Posted on Apr 06, 2014
5 Related Answers
Anonymous
SOURCE: Washer does not spin
I had the same problem in october- my had a bad wiring harness, some board problem, and a bad sensor. if it hadn't been under warranty the cost of parts alone would have been over 1000bucks.
Posted on Jan 09, 2008
yan candie
  • 39 Answers
SOURCE: Whirlpool washer grinding noise when draining
there could be something in your pump.....remove the pump and see if there is not something inside...
Posted on Jul 04, 2009
canbruce75
Bruce Canfield
  • 1776 Answers
SOURCE: f1 code on whirlpool cabrio top load
This is from a service bulletin. This may be of interest to you. There have been many problems with these machines in this area. Anyway, I sympathize and hope this helps. Best wishes.
CORRECTION:
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 – CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A – C above, and verified that there are no issues
with the air pressure system.
Posted on Aug 09, 2009
Corey Bendetti
  • 180 Answers
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Posted on Nov 27, 2009
Toby Gomes
  • 38 Answers
SOURCE: I have a Cabrio top load washer, Model WTW6300SWD
you have a cracked motor housing at the bottom of the machine. lay the machine on its back, remove centre bolt with allen wrench, pull off rotor. Remove four bolts holding the windings. Lift off windings, unplug wires and speed sensor. Inspect plastic housing with windings. You will see cracks. There's your problem
Posted on Oct 24, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Cabrio washer stops spinning and doesn't restart
it sounds like the water pump is not emptying properly, blow down the water outlet pipe to see if is clear if not go to the water pump and clean it out there is probably a button , paper clip or other debris preventing it from doing its job eric
Dec 25, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio makes excessive noise during spin cycle
Your model has a bearing under the tub which is probably going bad and needs to be replaced. cabrio washer bearing replacement YouTube
Oct 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio model wtw5500xw0 spins loud
The cabrio has a shaft that runs between the wash plate and the rotor located under the washer. The usual cause for noise during spin is something that has made it's way between the spin basket and tub. But it's best to try and determine if the noise is from under the washer or inside the washer, that way you aren't randomly taking things apart. See if you can pin point the location of the noise.
Oct 18, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
My cabrio wtw6700tw1 does no rinse so the water not drain out of the basin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio .....
I imagine it it has detected suds and is doing mini loads to correct the problem. I have a manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio agi stops after wash cycle
you may need a new timer. yes have it looked at.
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool WTW6400SW Cabrio Washer Logo
362 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
