SOURCE: microwave seems to turn on when door latch is opened
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on. The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent. Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second. That's perfectly normal. The relay on the control board must also be turned on before it will actually be cooking.
SOURCE: Microwave Steams Up, Heats Up, and Shuts off!
first of all your mwave needs to be properly ventilated .the problem is your magnetron when heated the thermal cutof switch cutts out power to magnetron.works again when cool.change magnetron
SOURCE: Microwave Will not work
This is usually a bad door swithc or loose or broken door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
SOURCE: when I open my microwave door, it starts running
In most cases, it's not actually cooking, but instead the fan, turtable and light may be on. Yet it does need attention.
What this usually means is that you have a shorted door switch or a bad door switch mount.
It's easy to tell if it's actually cooking, just place a cup of water inside and see if it heats.
If so, that could mean a stuck relay on the control board. If so, we repair these for customers nationwide with our guaranteed $39.95 service. Far less than a new board.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: GE microwave Turnable turns on opening the door
Thanks for the photo of the label!
It shows the FCC ID number, which I used to find schematics at the FCC Web site.
The problem is a shorted primary interlock switch.
This is the door switch which has two black wires connected to one terminal and a black and a blue wire connected to the other
terminal.
See these files for help:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can usually find
model number here.
If a switch is all you
need, we offer a universal type for only $5 postpaid which you can
order here.
We're
happy to help you with free advice and we'd appreciate your
